    Results 1 to 4 of 4
      Jun 2006
      Katy,TX
      Urethane shackle bushings choices?
      So what are you guys/gals with leaf springs using for shackle bushings? I know urethane binds ,doesn't flex(good and bad),and I have yet to find any that actually fit in the chassis and aren't too big! Rubber flexes good and bad. Del a lums don't bind but don't allow any flex at all.
      Need some for mainly a drag car so roll isn't as much of an issue as a cornering carwith urethane already in the springs. Even O Reilly doesn't stock the rubbers(and how many second gen F bodies were made?). And as I said the Energy urethanes I have don't even fit unless I chuck them in a lathe!
      USA
      That's strange...
      The Energy Suspension Urethanes don't fit ??
      They usually make good stuff.
      I used the Polygraphite ones on my '69.
      They make noise ...
      Probably bind too.
      .....I want a 3-link.
      If your car is primarily gonna' be street / occasional drag car , put the stock rubber back in.
      Call Year One..
      They have them..
      Jeff Tate
      U.S.A.
      Jun 2006
      Katy,TX
      This particular car I'm working on now is going to be strictly drag so roll isn't as big a deal on it. Cal Trac split leafs with aluminum in front and poly in the rear so I was thinking rubber in it on the uppers.
      Since Global uses a spherical in the high end springs to allow roll what about their kit that has Del a lums in all three spots for roll?
      Jun 2006
      Katy,TX
      Since Global uses a spherical in the high end springs to allow roll what about their kit that has Del a lums in all three spots for roll-there would be almost none?
