Results 1 to 7 of 7
10-20-2009 #1
- Join Date
- Aug 2009
- Posts
- 277
Tire size for a 18 X 9" rim and 18 X 8" rim
Looking at a 18X9 rear and a 18X8 front (maybe 18X7). Looks like a 25540R18 for the rear and either a 22545R18 or a 23545R18 for the front. Thoughts?
10-20-2009 #2275/40-18 or 285/35-18 rear.
245/40-18 front.
I'm running 245/40-18s and 275/40-18s on 9" wheels front and rear on the Tempest.Bart F.
'64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
'64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser'02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
10-20-2009 #3
- Join Date
- Aug 2009
- Posts
- 277
How much space do you have between the wheel wheels and the tires? I have measured my wheel wells and with 275's I might have 1/4 to 3/8" clearance
10-20-2009 #4I have about 1/2" on either side of the rear tire.
No mods to the inner wheelwells, no cutting or rolling of the fenders.
10-20-2009 #5
- Join Date
- Aug 2009
- Posts
- 277
The area that I have the greatest concern is the rear inner part of the wheel tub. There is quire the arc to it that makes it tight. Maybe this area is different on the 64 verses the 66?
10-20-2009 #6Probably not much difference between the '64 -'65 and '66 -'67 wheelwells.
If anything most would consider the wheelwells to be a little tighter on the earlier cars.
You are correct, that area at the bottom rear is the tightest. On my '64 GTO I did a little hammering so my 10X28 Goodyear slicks wouldn't rub in that area, they were mounted on a 15X8.5" wheel. The pic below is the driver's side from inside the trunk, you can see where the seam between the wheelhouse and trunk floor has been pinched from the hammering.
The 275-40-18s are quite a bit shorter at 26.6" so they fit a little better, plus they dont have that sharp corner where the tread ends like a slick does.
10-21-2009 #7
