    Results 1 to 4 of 4
      Sep 2007
      67 lemans torque specs
      Hi guys,
      Converting a 67 Lemans from 4 wheel drum to front disc as a class project. Need torque spec. for upper/ lower ball joints and outer tie rods.
      Thank you,
      ED
      Wichita, KS
      are you talking about the large "castle" nuts that screw on to the joint itself? if so you dont even really tighten them.
      67 GTO, LS2, T56
      WILWOOD, FORGELINE, RIDETECH
      So Cal
      Specs from GM.....
      Quote Originally Posted by 67goatman455 View Post
      From the '67 Pontiac Service Manual:
      Nut -Upper Ball Stud......50 Lb. Ft.
      Nut -Lower Ball Stud (Tempest)......82 Lb. Ft.
      Nut -Tie Rod to Steering Arm......40 Lb. Ft.
      Tempest specs same as LeMans and GTO, same car just different options and trim levels.
      Bart F.
      '64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
      '64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
      '02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
      Sep 2007
      Bart,
      Exactly what I was looking for.
      Thank you,
      ED
