    Results 1 to 4 of 4
      Feb 2007
      USA, TN
      Delphi Connector on Autometer Gauges
      I'm installing Autometer electronic Phantom gauges in my dash. Does anyone know if the Delphi Series 56, 3 pin female connector will fit the the fuel, volt and oil gauges? Will the 8 pin female fit the speedo and tach?
      Feb 2007
      USA, TN
      The good news is the Delphi 56 series connector fits the Autometer gauges. It is a three pin connector, part number 02984378. I got the connectors for the tach and speed from AWW. They appear to be a Molex connector of some type. Below is a picture of the Performance Vehicle Works dash with most of the gauges in it.
      Sep 2007
      Edmonton, Alberta
      Clean job wirring those gauges, looks very good. If I may note, be sure to ground the HU chassis and possibly the rca pre-out terminals if you experience alot of "noise". Pioneers have a small reputation for hard to trace noise issues.
      Feb 2007
      USA, TN
      Quote Originally Posted by bbcc View Post
      Thanks for the heads up. The dash is metal and I'll have an 8 gauge ground going to it. I'll also ensure the dedicate HU ground is connected. I don't plan on using the preouts, but you never know.
