View Full Version : Rear end clamp for brake lines
scherp69
10-18-2009, 12:58 PM
This fall/winter I plan on running the brake lines on the car. Since I already have the rear end powder coated, I can't weld on any brackets to hold the brake lines onto it. What are you guys using to secure the brake lines to the rear housing??
brans72
10-18-2009, 01:03 PM
Good ? to ask waiting for a reply along with you. I did see something a while back where the clamp was screwed down in to housing but was only a pic.
ammoyer
10-19-2009, 08:04 AM
http://www.speedwaymotors.com/Stainless-Steel-Line-Clamps,1975.html?sc=WGB&utm_source=GoogleBase&utm_medium=feed&utm_campaign=GoogleBase
I've used ones like these several times across 9" housings. Just drill and tap the tube for the #10x32 screws provided. Usually I'd try to bend the flat portion of the tab so that the clamp would follow the radius of the tube. I would avoid putting any on the center housing, especially if the rear is assembled to avoid getting any drill and tap shrapnel in there. You should be fine on the tubes though.
Adam Moyer
MonzaRacer
10-19-2009, 10:49 PM
Still need to have axles out to clean stuff up if you drill and tap, I have actually used CV boot clamps and small piece or rubber hose, their stainless and wont rust and can be replaced easily.
tumper93
10-20-2009, 03:52 AM
GM used a plastic wrap around type clamp just for this on all trucks beginning in the late 90's. I use them and have taken some off of wrecked cars that have rearends replaced that come in the shop. They are perfect considering that is what they were designed to do. Check it out and I am sure you will use them.
John Wright
10-20-2009, 04:32 AM
I've heard of some folks using an epoxy type material to glue clamps onto the axle tubes for the 9" rears from Currie.
.....maybe Protour73(Scott) will chime in, I think he used them.
edit: http://www.nastyz28.com/forum/showpost.php?p=1156209&postcount=138
scherp69
10-21-2009, 01:46 PM
Thanks for all the suggestions guys. The funny thing is after I posted this question, I started thinking.....the rear end has a back brace welded on. I could just as easily drill and tap some holes right into the back brace and run it along there. I also like the idea of just running it along the rails and then the floor. I already have the rear together so I don't feel like taking it apart, but I guess if I do decide to run it along the tubes, I will have to take it apart. Thanks again for all the responses.
