    Results 1 to 15 of 15
      Aug 2008
      17X11 ZR1 what size wheel adapter? 69 Firebird
      I have a 69 Firebird with drum rear brakes. What size wheel adapter could i use to make them fit with out doing mini tube. my ZR1 are 36mm offset 17X11 heres a picture. From my searches i seen most people say dont go more than 5.75" backspacing. What size adapter will work?
      Jul 2007
      Olathe, KS
      Hi Stroked,
      If you know offset and wheel width, you can determine current backspace. It's been discussed quite a few times on the forum if you're needing more detail.
      Backspace = ((wheel size + 1) / 2) - (wheel offset / 25.4)
      plugging in your wheel you'll end up with ~4.58" of backspace. To get the 5.75" of backspacing you'll need about a 1 3/16" adapter.
      I would start by measuring your car and determining what kind of space you have to work with. I typically shoot for at least 3/16" clearance to the front, and at least 1/2" clearance in the rear. When determining clearances you also have to keep tire size in mind as well. Usually your tire will overhang your wheel by a small distance. I just finished fitting a 275 tire on a 9.5" wheel and end up with .2" overhang off of the wheel.
      For this wheel to work on your firebird, it will require work to your inner wheel house.
      Aug 2008
      Ahh i see, so basically if i had a 7.5 backspacing i would use 2.5" adapter. I'll have to measure out the rear wheel well to see if it will even fit. I'll measure it out and the actual backspacing of the rear wheel too.
      By the way, i been reading that people with 17X8 running zero offset have no issues on front. I might go that route on front.
      The tire over hang your talking about must be "section width". I dont mind pounding in the rear wheel well a little just as long as i can get my 315/35 17's tires on without cutting or welding. i wont be running tail tips to the rear that should give me more clearance maybe.
      League City, TX
      Hopefully there is a little more room under the firebird. I have 17x9's under the back of my Nova with 275 on them. They fit good, but it took a fender lip roll and 3 different spacers to figure it out. I ended up with a 1.5" spacer on the drivers side and a 1" spacer on the passenger side.
      More info in this thread that might help out:
      https://www.pro-touring.com/forum/sh...ad.php?t=43322
      John Brown
      1971 Nova - Project Car
      1990 Silverado - Ridetech StreetGRIP
      Instagram @wilwaxu
      Facebook @wilwaxu
      An 11" will not fit in a '69 without tubbing.
      Largest I heard anyone manage was a 10" but the fender lip was rolled.
      Oregon
      Quote Originally Posted by 68Formula View Post
      68Forumula is correct, there is no way to fit an 11" wide wheel under a first-gen F-body without some sort of mini-tub, full tub, etc. Spacers are somewhat of a moot point. The only option short of some sort of tub kit would be to lift it with longer shackles and let the tires hang out the sides like the drag guys do.
      Tobin
      KORE3
      It's what I does.
      Aug 2008
      cool thanks for the info all.
      I just sold them on craigslist today! all gone i got $300 bucks for it.
      Aug 2008
      I decided to run 2001 WS6 rims 17X9 with 275/40 17 tires.
      What size spacer or wheel adapter should i run?
      69 Firebird (Sport Coupe 350) Antique Gold
      Dec 2009
      El Dorado Hills
      What I would do is base your dimensions on a 17x9.5 wheel with 5.5" back space. So if those wheels are currently a 7" back space you will need a 1.25" spacer. Be sure to use a good quality hubcentric spacer.
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
      Aug 2008
      Awesome, that sounds great i'll look into 1.25" spacer.
      Can you recommend a place to buy the spacer from, ive never bought one before. Would the hubcentric spacer work on drum brakes.
      Dec 2009
      El Dorado Hills
      Google MotorSport-Tech. He'll custom make anything you need. Be sure to tell him they need to be hubcentric. The material he uses is Alcoa 6061t6 billet aluminum. IMO thet aren't cheap but great quality.
      I'm pretty sure they will work with drum brakes and I'm not 100% sure but once you go to disk brakes the back space may change a bit.
      Also, if you intend to use a 275/40 up front prepare to cut some of your inner wheel well out. Not a big deal and wont be noticed.
      Gaetano Cosentino
      Oct 2006
      Corona, CA
      I can make you a billet adapter for 75 bucks each, and we're a forum sponsor...
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by DriverzInc View Post
      Now you tell us.........If I would have known I would have picked them up from you guy's.
      Gaetano Cosentino
      Sep 2007
      Montgomery, Tx
      Alright this is great news
      Gary Rys
      69 Camaro
      Easley, SC
      Quote Originally Posted by STROKED View Post
      Post up pics when you get 'em on. Those wheels will look great on your car !
      David
      Current rides:
      1970 Firebird FORMULA 400
      1964 Pontiac Tempest
      1986 Mustang LX 5.0 coupe
