    Results 1 to 11 of 11
      Netherlands
      yellow dot on Nitto race tire
      guys i know a guy who hase this yellow dot ore cirqel on the side of his nitto raceing tiers he whants to know what it is and why its there for!!!> tanks
      TuoCo, CA
      As far as I know, that's where you're supposed to line up the valve stem.
      Steve
      '68 Camaro - SBC, TKO600, 3.73 Moser 12-bolt, Speedtech, ATS-AFX, Hotchkis, Forgeline, Ron Davis and C5 brakes (Kore3), Holley Terminator TBI.
      Check it Out Here
      Morehead City, NC
      Quote Originally Posted by eville View Post
      That is correct. The tire guys should have known that when they installed them.
      May 2008
      SoCaL-Pico Rivera
      close enough....
      Greenwood, SC
      Quote Originally Posted by 1badchevelle View Post
      close enough....
      Haha....
      JC Scott
      Rustburg, Virginia
      What do those colored dots on the tires mean ?
      The colored dots identify the final finish inspector that inspected that tire. We used to use yellow paint stamps with numbers but the numbers were usually illegible. When we got back a tire that should have never shipped to begin with we often had trouble figuring out which of our inspectors needed a tad more training. Now they each have a different color paint pen.
      http://www.americanracertires.com/content.php?id=4
      Netherlands
      And why is that????
      Feb 2009
      Portland OR
      In motorcycle tires that identifying feature is usually two small marks next to each other and is sometimes referred to as the "snake bite". The purpose of the mark is to identify either the lightest or the heaviest part of the tire. This is used for balancing purposes. The reason the guys say to put it near the valve stem would indicate to me that the yellow dot is marking the lightest part of the tire and would be put next to the stem which in theory should be the heaviest side of the wheel. You can see that the effort would be to offset the weight differences in the wheel/tire. In any case I would check with the tire manufacturer to see what the yellow dot means because it could be either the light or heavy side. Once you get it figured out is should make balancing easier.
      Jul 2003
      Anaheim Hills, CA
      Yep, what they said about the heaviest section of the tire. Like it up with the Valve Stem.
      As a side bonus you can see if you tire is ever spinning on the wheel.
      I've found that he dot is only on one side of the tire.
      1968 Track Rat Camaro:
      Rustburg, Virginia
      http://www.nittotire.com/#index%2Econtact
      Ask the company who makes the tire
      Netherlands
      Guys i like to make a apology , as i alredy knew what its there for, but i needed a hounest upinion about it. we had a discussion about it on a dutch forum, where a tire guy who works for a company said the dot is only there for aproval. i gues they dont deal with race cars and race tires. we said its there to line up with the valve stem. for better end ez balansing. i like to feel good doing 190+ mph knowing i dont have a inbalance in my tires.
