    Results 1 to 6 of 6
      charleston, SC
      Screws for mounting fuse block
      Anybody use a diiferent screw for mounting the fuse block to the firewall? The AAW kit has 2 sheetmetal screws that screw in from the inside and I don't want an exposed screw on the other side of the firewall. Will a stainless machine screw with nut and locking washer work?
      Robert's 1969 Camaro - 2002 LS1/T56, 10pt cage, Global West Stage III front suspension, HTH truck arm rear suspension, Sprint Cup 9" full-floating rear end, Fikse Mach V 17" up front 18" in the back and still working on it...
      McAllen, TX
      That's a good question..here's what those ugly screws look like
      Armando Garcia
      67 RS/SS Camaro
      07 Ford Mustang GT/CS
      02 Harley Davidson F-150
      Rustburg, Virginia
      How about a rivet?
      Oct 2008
      Durham,NC
      How about cutting the head off and welding it to the metal then install fuse box and install 2 nuts if possible?
      Feb 2007
      USA, TN
      Drill it through and install bolts with nuts. Have the nuts face inside. You can use black oxide, stainless or paint the bolts to match your fire wall. Apply a little strip caulk to the bolt heads if you are worried about leaks or scratching the paint.
      I did this for my AC
      charleston, SC
      Good Ideas. Thanks.
