View Full Version : Screws for mounting fuse block
scogin918
10-09-2009, 06:32 AM
Anybody use a diiferent screw for mounting the fuse block to the firewall? The AAW kit has 2 sheetmetal screws that screw in from the inside and I don't want an exposed screw on the other side of the firewall. Will a stainless machine screw with nut and locking washer work?
texasdvldog
10-09-2009, 10:55 AM
https://static1.pt-content.com/images/pt/2009/10/IMG_0251-1.jpg
That's a good question..here's what those ugly screws look like :hmm:
John Wright
10-09-2009, 11:04 AM
How about a rivet?
brans72
10-09-2009, 12:03 PM
How about cutting the head off and welding it to the metal then install fuse box and install 2 nuts if possible?
TnBlkC230WZ
10-09-2009, 03:31 PM
Drill it through and install bolts with nuts. Have the nuts face inside. You can use black oxide, stainless or paint the bolts to match your fire wall. Apply a little strip caulk to the bolt heads if you are worried about leaks or scratching the paint.
I did this for my AC
https://static1.pt-content.com/images/pt/2008/09/DSCN1633-1.jpg
https://static1.pt-content.com/images/pt/2008/09/DSCN1634-1.jpg
scogin918
10-09-2009, 04:48 PM
Good Ideas. Thanks.
