Results 1 to 9 of 9
Thread: 17" Tyre Sizes
10-08-2009 #1
- Join Date
- Feb 2009
- Posts
- 64
17" Tyre Sizes
Can anyone help me out. I want to buy matching (same brand, but not same size) tyres for my car (17").
Problem is finding the rear sizes that I want/need.
I am trying to find 305's or 315's in 17" that will be as tall or taller than the fronts (255/40/17 or 255/45/17). Even 295's at the rear with the right specs would be OK.
Just to complicate matters, here's the curve ball: my rear ratio is 3.23. Would it be better to run taller/shorter rear tyres and how would that affect the recommendations above?
Thanks for the advice
Rich
10-08-2009 #2
- Join Date
- Sep 2007
- Posts
- 162
Rich,
You need to fine tune your ideas. A 295 tire is considerably narrower compared to a 315. What look do you want, can they fit, etc? Not sure if you understand the tire sizes:
255 = tread width
40 = aspect ratio = 40% of 255 = sidewall height
17 = wheel diameter
As far as rear axle ratio and tire size: a smaller diameter tire will give you faster acceleration but higher cruising rpm's; inversely a larger diameter tire will give you slower acceleration and lower cruising rpm's.
Hope this helps,
ED
10-08-2009 #3Here is on e of the best tool I have seen to halp calculate the tire sizes, wheel backspacing, etc.
Plug in your numbers, and you will see a representation.
http://www.rims-n-tires.com/rt_specs...t2=Z06%20setup
10-08-2009 #4
- Join Date
- Feb 2009
- Posts
- 64
Hey guys
thanks for the ideas.
All I am asking is: is there a brand of tyres (or two, or three.....the more the merrier) where I can get fronts in 255/40/17 or 255/45/17 AND rears in 295/305/315 (17") with a profile(aspect ratio) such that the rear tyres will be taller than the front ones? Do such combinations exist?.
I see that the chart provided will help a lot, but if anyone has a quick answer it would be appreciated.
Rich
10-08-2009 #5
- Join Date
- Feb 2009
- Posts
- 64
Does anyone make a 315/40/17 tyre? I think that that would give me the rear height I need and then I can match the front.
The rear wheel well is wide enough to take just over 12.5" section width of tyre and have enough clearance. I am also trying to get the rake/stance "right".
Thanks again.
10-08-2009 #6I am not sure if you wanted a street tire, or a track tire, so I'll assume a street tire:
Nitto 555 Extreme Performance has the 255, 285, 315,
Here are some numbers plugged into the handy-dandy tire-comparer:
http://www.rims-n-tires.com/rt_specs...&text1=&text2=
Info on the tire sizes avail:
17"
245/45ZR-17 89W
255/40ZR-17 94W
255/45ZR-17 92W
255/50ZR-17 101W
P275/40ZR-17 98W
P285/40ZR-17 95W
315/35ZR-17 102W
http://www.discounttire.com/dtcs/tir...Selected=78259
You can also get the NT-01's for the track in the same sizes (255/40 & 315/35)
http://www.discounttire.com/dtcs/tir...yp=Competition
10-08-2009 #7
- Join Date
- Feb 2009
- Posts
- 64
Thanks MC84. The combination and brand that you have shown is the best fit that I have found so far.
A 315/40/17 would probably be ideal for me........it's a theoretical size that I put into the calculator but can't seem to find an actual tyre that size. Still hoping in case anyone knows of same.
Rich
10-08-2009 #8
