    Results 1 to 7 of 7
      Arlington Heights, IL
      small block car with big block springs?
      i have big block 2 inch drop springs from hotchkis that i put in when i had my big block still. i now have a small block with aluminum heads. it sits just a tad too high. am i better off cutting my springs a little bit or should i buy some small block springs?
      1969 Camaro under construction.
      1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
      montreal CANADA
      i too would like to know, i went from a 455 olds to an Aluminum Pontiac block...
      Wayne S
      79 Pontiac Trans Am WS6
      krepower.com Aluminum MR-1A Pontiac 505cid
      04 Ram SRT-10 Viper spec Tremec T-56
      no idea for suspension yet....
      Year One billet snow flakes soon
      SpitzKraft HID conversion kit
      http://protouring79ta.monchar.com/
      Jun 2009
      Since they are a linear rate spring and don't have flat ground ends you can cut them. The published rate on these springs is 600 lb/in which is fairly high already for a small block car. Cutting them will increase this rate too so ride quality will suffer. How is the ride now with these springs and the small block? The cheapest solution is to just try it and see if you can live with the ride....although you could probably sell an uncut set of springs so you have to factor that into the equation too!
      san jose,ca
      i drove a 69 with the same set up and it was nice all we did to get the ride height where we wanted it was cut the spring with a 90 degree air cut off wheel and some antifreeze, just cut slow and only a little at a time.
      Eli
      68 camaro more plans then funds! lol
      http://s34.photobucket.com/albums/d1...view=slideshow
      IL/TN
      just cut the spring just make sure you cut only about half the amount you want to lower off the spring, in other words if you want to lower 1" measure the spring free length and cut off 1/2", in general this is about 1/3 to 1/2 of a coil don't worry about the increase in rate it will only be about 2-3% in other words nothing you will feel, as for cutting use a cut off wheel don't worry you wll never put enough heat in the spring to alter its properties
      https://www.protouringf-body.com "doing what they say can't be done"
      alright sounds good to me. im cuttin them!
      I cut my front BB Moog 5536 springs
      Free height from 15" to 13.25" Rate went from 487# to 556#
      This is about 8% per inch
      CORRECT formula for
      STIFFNESS OF COIL SPRING
      K = W^4 x G / N x D^3
      K is the Spring rate (Ib/in) I calculated 486.7# (moog 5536 table says 487#)
      SO THIS FORMULA IS REAL CLOSE
      W is Diameter of spring wire (in.) .687 (.687^4 = .2227547)
      G is a constant of 1,406,250
      .2227547 x 1,406,250 = 313,248.8
      N is the Number of "free" coils (before cut was 8) (after 1.5 coil cut, which removed about 1 active coil + dead 1/2 coil) that would have been in contact with the LCA seat, so I'll use 7 active coils
      D- Diameter of
      spring coil (in.) 4.317 (4.317^3 = 80.453723)
      center to center
      313 248.8 / (7 x 80.453723) = 556#
