Results 1 to 20 of 23
09-29-2009 #1
New to Pro-Touring
- Join Date
- Apr 2009
- Location
- The most easterly point in North America,NL Canada
- Posts
- 32
New Hotchkis suspension, 67 Camaro sits too high!
To say the least i'm pissed.I just finished installing my Hotchkis suspension kit on my 67' Camaro and my car sits higher than it did stock!Oh it handles great but looks like crap.It's got 2" drop coils and it looks like it needs to go down about 3".Is it possible the front sway bar could be holding the car up?The handling is nice but I would have been more happy just cutting my stock springs to get the height I wanted.How much can you safely cut off the Hotchkis Springs?Has anybody else run into this or have any ideas what I could do?I posed questions on here earlier about the fact I have aluminum heads and was assured it wouldn't be much of an issue.The car has a small block and I have already confirmed I have the right parts.Thanks in advance for any help.
09-29-2009 #2
Banned
- Join Date
- Aug 2003
- Location
- Orlando, FL
- Posts
- 8,745
Three things.
(1) Keep in mind many cars have very worn springs and already sit loewer then stock.
(2) Your springs will settle, so give them a couple week
(3) You can trim the springs quite a bit.
But don't do anytihing for a couple weeks. Also, make suure your lower control arms are not tighten will the front suspension was hanging. I like to double nut them and let them swing.Last edited by parsonsj; 09-29-2009 at 07:52 PM.
09-29-2009 #3
New to Pro-Touring
- Join Date
- Apr 2009
- Location
- Posts
- 32
The springs I took out were a few years old but not worn.the car didn't sit low before the change and everything in the front end seems pretty free.How much is quite a bit on the coils?
09-29-2009 #4If you have rubber bushings in the control arms and you tightened up the arms while the car was in the air (arms drooping) then the bushings are actually pushing the car up.
If you've got solid bushings, like Del-A-Lums, then I don't think it makes a difference where the arms are when you tighten them.
If they are poly bushings then I also don't think it matters.
But, again, if they're rubber, you have to do it the right way.Jason Scheer
09-29-2009 #5
