View Full Version : How to remove play in c-clips
tumper93
09-23-2009, 05:07 AM
I was wondering if anybody had a suggestion on removing the play when running c-clips. I need to reduce the in and out movement as much as possible. I haven't heard any ways other than measuring the c-clips and running the thickest ones I can find, but that could take quite a bit of time and money since most places don't tock these!
big gear head
09-23-2009, 06:05 AM
What differetnial do you have? If it's a clutch type limited slip (posi) then you can shim or replace the clutches and reduce the axle end play. As the clutches wear the axle end play will increase.
tumper93
09-23-2009, 06:20 AM
It is a 4-series GM eaton.
big gear head
09-23-2009, 07:21 AM
Shim or replace the clutches. If the clutches are still good then shim them. If the clutches are worn out then replace and shim them. I rebuilt one about 3 days ago and shimmed it so tight that the cross shaft wouldn't go back in. I had to remove some shims from the clutches so I could get the axles in and put the cross shaft back in. It has about .005 clearance now.
