View Full Version : Jeep headlight assembly
EL T1
09-20-2009, 04:38 PM
I took a pair of '08 Jeep Renegade headlights from a totaled Jeep at work. Thinking they just might fit the Camino, well they fit virtually perfect. Even the stock trim ring fits right over it. Sweet! Heres some pics.
I will get some pics installed later as its drizzling out now.
Now can anybody tell me how to go about wiring these up. I can probably get the stock pigtail to connect to the bulbs. But where do I go from there?
PICS IN OTHER POST
MCMLXIX
09-21-2009, 02:21 AM
Well the pics didnt show up.... maybe it me, maybe bad links...
Not sure hwhat type of bulbs but here are some ceramic connectors...
http://www.rallylights.com/detail.aspx?ID=1408
Use two relays, one for low beam and one for hi.... use the factory wire to trigger the relay. Use a good heavy gauge wire to power hte lights....
EL T1
10-27-2009, 08:42 PM
https://static1.pt-content.com/images/pt/2009/10/k1faya-1.jpg
https://static1.pt-content.com/images/pt/2009/10/iz96iu-1.jpg
https://static1.pt-content.com/images/pt/2009/10/fx5xmq-1.jpg
https://static1.pt-content.com/images/pt/2009/10/30vi13m-1.jpg
https://static1.pt-content.com/images/pt/2009/10/23vz5fl-1.jpg
Rhino
10-28-2009, 06:25 AM
Just as a clarification for those who may not be familiar with the Jeep lineup, you're speaking of the Liberty Renegade correct?
I know you can find '97-'06 Wrangler (TJ) H4 replacement headlight housings fit GM vehicles with minimal modifications.
EL T1
10-28-2009, 06:31 PM
They came off of one of these.
https://static1.pt-content.com/images/pt/2009/10/2008jeepwrangler0001A-1.jpg
Rhino
10-29-2009, 05:17 AM
That particular picture is a Wrangler Rubicon, but the headlights should be the same as the standard 08+ Wrangler. Once you mentioned it, I started looking at a lot of the Jeep headlights and was curious about the new wrangler. Do you happen to know if the headlights are mounted at an angle? The grill does slope back slightly, I'm not sure about the headlights.
EL T1
10-29-2009, 06:55 AM
they are bolted straight to the core support while the grille does have rake to it. i just took some pics and will up load them later. Rhino, that pic is the exact model jeep the lights are from. i just didnt know the name when i first posted..
EL T1
10-31-2009, 09:54 AM
shows how they mount stock
https://static1.pt-content.com/images/pt/2009/10/2q1xswk-1.jpg
https://static1.pt-content.com/images/pt/2009/10/jg0abq-1.jpg
The bulbs are H13
Twentyover
10-31-2009, 11:13 AM
OK- help me out here-
Why is this better than an H4?
Rhino
10-31-2009, 12:20 PM
It actually appears to be an H4 (or similar halogen replacement)
The nice thing about this is that we'll probably be finding them in salvage yards as a readily available, cheap housing to retrofit.
The only thing that worries me a little is how bug-eyed the lens seems. I'm wondering if those of us with headlight doors may run into any clearance issues.
mc84_zz4
11-04-2009, 11:54 PM
Not attempting a hijack, just more options:
For a low budget item, you can also buy these for under $30 a pair (bulbs included)
Not sure how much the 'yards are charging over there, here they are proud of their stuff...
Autopal lights on flea-bay:
These are steel housing and nice optical glass lens:
https://static1.pt-content.com/images/pt/2009/11/BSpSUTBGkKGrHgoOKkYEjlLmTDiBKENzJoVC_12J-1.jpg
http://cgi.ebay.com/ebaymotors/97-98-99-00-01-02-03-04-05-06-JEEP-WRANGLER-HEADLIGHTS_W0QQcmdZViewItemQQhashZitem3ef4a8dde8QQ itemZ270392679912QQptZMotorsQ5fCarQ5fTruckQ5fParts Q5fAccessories
They also have the free-form design, composite reflector housing, glass lens:
https://static1.pt-content.com/images/pt/2009/11/93f0_12JPG-1.jpg
http://cgi.ebay.com/ebaymotors/97-98-99-00-01-02-03-04-05-06-JEEP-WRANGLER-HEADLIGHTS_W0QQcmdZViewItemQQhashZitem3ef4a8dddfQQ itemZ270392679903QQptZMotorsQ5fCarQ5fTruckQ5fParts Q5fAccessories
Yes, I know they are another H4, the advantage is you can find all kinds of bulbs for them.
