View Full Version : Tranny clearance with speedtech frame
tino160
09-17-2009, 11:58 AM
I have heard that the motor sits lower with the speedtech frame.
I will be mocking up soon(ls1 with 4l60e)and wanted to know if I will need to order another tunnel to raise mine.(if I need to raise it I will be using a strip out of another tunnel so it looks factory).one more question,If I make room for a 4l60e will a t-56 fit or is it bigger,Thanks.
silver69camaro
09-17-2009, 01:25 PM
If the motor sits lower than stock, there shouldn't be any problems.
killer69
09-17-2009, 01:51 PM
the motor sits as low as possible the oil pan (ATS or Autokraft) is about 3/8 above the rack and it is off set to the passanger side 3/4" to clear the powersteering fitting on the rack. you should have no issues fitting the transmssion
tino160
09-22-2009, 10:55 AM
Rodger at speedtech told my shop guy that the motor sits at the same height(or very close to it), just a little to the side.I will have to cut the tunnel to fit the bigger tranny.Do you agree,or did you think I was talking about something else?
killer69
09-22-2009, 07:24 PM
if i recall the 4l60 is about the same size as a 700r4??? and we just did an install in Rogers car with a BBC and 700r4 and it fit just fine
http://www.tciauto.com/Products/TechInfo/trans_dims.asp
check the link to see all the dimentions
the 93-95 4l60 dimentions are identical to the 700r4
so i would say NO cutting required!!
CraigMorrison
09-23-2009, 10:07 AM
It all depends on what T56 you are using - If you are using the Viper T56 you might need to make more room. Viper tranny has the viper logo on the side of the gearbox......
killer69
09-23-2009, 06:29 PM
i agree we did one with a lakewood bell housing and it needed the tunnel cut and raised up. but i think????? if you were to use a Quicktime of stock chevy bell you may be close. the t56 is a pretty big trans up top with the three inspection covers and top mounted internal rail shifter???
