    Results 1 to 10 of 10
      Bonney Lake, WA
      Best oem spindle / knuckle
      I am looking for input on spindles. I would like to find a spindle that has ideal KPI, wide spread between upper and lower bj. I am open to hear more info regarding important considerations on a spindle as well. Ive looked at some of the spindles at Stock Car Products, but I think I would like to stay with something oem so if I need a new one they are easily attainable. I am working on a scratch built IFS on a 68 Mustang. Im in the planing stages. I am open on offset / backspacing, Diameter and width on the wheel.
      san diego
      i want to follow this thread. since i just built my own front suspension for the falcon.
      as for spindles, things to consider: material-lighter the better. brakes-whats available. steering arm-i would keep it a rear steer.
      St George Utah
      What about fitting a newer mustang strut into the car with say a QA1 tubular k member???
      i am not sure on the track width but it is a good set up and the layout is bacically the same.???
      just an idea
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Bonney Lake, WA
      Qa1 Strut
      Ill have to check that out. Did not even cross my mind. I was pretty focused on the unequal length a arm setup.
      Bonney Lake, WA
      k member good for drag or curves
      Is this setup more for straightline or will it suit a road racing type application. I want to go fast through the twisties.
      san diego
      strut suspension on paper does not sound very good when compared to a SLA. but it actually performs very well. It was origally desinged to be a cheaper OEM suspension that would allow more room in the engine compartment.
      i have a 95 mustang with stock strut suspension and coilovers. i can pull 1G with a 245 sumitomo tire on all four corners.
      St George Utah
      altho the QA1 k member may be a little light duty it could be strengthened up to handle the corners, you could also check out a SN95 k member 94up but the track width is a bit wider than the earlier years, the strut set up is a good way to go . look at the saleen and steeda road race cars, hard to argue with that!!!
      big factor will be the width but even if you had o have some one off lowr control arms and manual rack made??? then agai you may not need it at all migth work with a high off set wheel??
      Blake Foster
      435-628-4300
      St. George Utah.
      Sep 2009
      St. Pete, FL/Deployed
      I like this idea and want to do something similar. I have another thread about the AJE k-member.
      Auburn, WA
      I'd look into the Wilwood Pro Spindle. Allows a variety of brakes to be used, front or rear steer, and a good ball joint spread. Very, very strong too.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      san diego
      Quote Originally Posted by silver69camaro View Post
      I wish i had seen that spindle when i built my front suspension. It looks great. I might need to do a redesign around that spindle.
