Results 1 to 10 of 10
09-10-2009 #1
Drill and tapping 10 bolt case for upper mount.
Just brainstorming planning my upper link mount on my 10 bolt. Id like to not weld onto the cast housing so I figure I could drill and tap the case for 2 bolts in front and reinforce the inspection cover and make it one with the pivot braket.
Does bolting the front to the housing sound like a viable plan?
Any suggestions for drilling and tapping cast iron?
Another one of my world class MS paint pics
09-10-2009 #2
- Join Date
- Apr 2006
- Posts
- 134
I've seen some companies make brackets for s-10 lowriders that just bolt to the rear cover. It must be fairly sturdy.
I take it this is on a leaf spring rear end with no 'ears' to bolt to.
How about a bracket that surrounds the nose piece?
09-10-2009 #3bracket near or around pinion is not a good location. Yeas this is a leaf spring car.
09-10-2009 #4
- Join Date
- Mar 2008
- Posts
- 952
how about a GNX rear cover?
either that, or get a rear out of a coil spring car and make a bracket that bolts in between the upper arm mounting ears.
09-11-2009 #5the GNX is a 7.5 if I remember correctly. Id like to not spend money that doesnt have to be spent The rear I have is set up with good parts.
09-11-2009 #6
