    Results 1 to 20 of 23
    Thread: Stupid iPod...
      Jul 2003
      Anaheim Hills, CA
      Stupid iPod...
      Ran into problem with my iPod Touch based audio system. Tom McBride at Bowler found out that the noise in the system was from using the Griffin TuneDock as an audio input device to the amp. He moved to using the headphone out jack and not only did the high-freq noise go away but the overall sound quality and volume when WAY up.
      So no problem, we will just use the headphone out jack to feed audio to the amp.. BUZZ! wrong answer.
      Seems that SOME iPod devices cut the output to the headphone jack when the unit is being charged (well, when it's docked). So we now have to put in a switch so that when I want audio we have to run off the Touch's internal batt and then flip the switch to charge but not have audio.
      I have to think this is a software deal since it's not something that happens to all models of iPod. For instance his daughter's regular iPod doesn't do this and it seems some updates activate this stupid function.
      Any ideas?
      1968 Track Rat Camaro:
      Crown Point, Indiana
      http://www.davidnavone.com/cart.asp?14&pid=178
      Steve,
      Have you tried this option yet? I was following your replies from JP's post. And Am looking into doing the same thing With my IPhone.
      Jun 2001
      Orlando, FL
      I've been loving my noise-free stereo in my car. The Navone product works.
      jp
      ​John Parsons
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by parsonsj View Post
      jp
      I don't think that was my problem though since it made noise even with the car off.. and the audio quality was crud.
      My problem now is that this Touch disables the headphone jack when docked.. which is stupid since many people use that jack to interface with the car stereos.
      St.Anne Il
      ill have to try it out on mine Steve i use the headphone jack in my truck and swore i charge it while driving.but will check only i dont use a dock just a cheapo type cig lighter charger..
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Jun 2005
      Greenwood, SC
      Quote Originally Posted by Steve1968LS2 View Post
      There's always the new zune hd!
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by dropit69 View Post
      My understanding is that some do and some don't and newer software updates cause it more than older ones.
      I also heard where Apple wants to make it so you can only use "Apple Certified" headphones with thier products, but that's another story for another time.
      St.Anne Il
      just checked mine Steve i can listen and charge at same time..its a gen 1 16 gig touch with cheapo charger though..not a dock..apple gets weird with wanting to have just there stuff on everything..the stock headphones suck ass..
      Darrin Stalnecker
      1968 Camaro LS1 T56
      Springfield, Mo.
      I dont have any suggestion to fix your issue but do agree that not all ipods are equal. My old 2g iphone had all kinds of interference when I tried to use it in my DD, my new 3Gs doesnt have it at all.
      1967 Camaro - Done!
      1968 Camaro - Underway
      Jul 2003
      Anaheim Hills, CA
      I heard the Gen 1s didn't have this problem but the later gens do.. thanks for confirming
      Marshall , MO
      I would guess that the dock is what cuts the head phone jack since it has audio out on it. I would also guess that if you got just a cheap cigarette lighter charger that it would not cut out the head phone jack. Should be fairly cheap to test belkin makes a ipod charging kit with the connections you would need. I think I picked ours up for less than $20.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Eastern Virginia
      Some more advise for you, don't go to version 3 of the OS software. I did & now the wifi barely works if at all. It is a known issue. I didn't research it before I installed it. I just assumed it was better, you would think me working for a software company I would know better.
      Scot
      86 Monte SS
      Jun 2001
      Orlando, FL
      Quote Originally Posted by Shep
      All my iPhone/iPods allow the headphone jack while charging with Apple gear connected to my Mac. But: in my car with my PAC AV2, it works as Steve described: audio comes out over the dock, and not through the headphone jack. Ergo, it's the dock, not the iPhone. I think a cheap "charge only" device is worth a try.
      Quote Originally Posted by Scot
      I hadn't heard that. Got a link?
      jp
      ​John Parsons
      Eastern Virginia
      Do a Google search for;
      ipod touch os 3 wifi problems
      Scot
      86 Monte SS
      Jun 2001
      Orlando, FL
      Apple has released a service bulletin on how to resolve the WiFi issues. If the software reset directions don't work, then the unit needs to be repaired or replaced. Sounds like the OS isn't the issue, but the upgrade path or the hardware is:
      http://support.apple.com/kb/TS1559
      jp
      ​John Parsons
      Eastern Virginia
      That tells what to do if there is NO connection, mine shows I have a connection, but it is slower than snails in December. Not a problem before going to 3. I'll try it & see what happens, but doubt it will make a difference.
      Scot
      86 Monte SS
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by shep View Post
      That's a good idea to try, but I got the idea from reading online that it was the unit, that's why some do it and some don't. But, it's worth a try.
      Fontana, CA
      Quote Originally Posted by formula View Post
      +1
      Been a Zune user for a few years.
      Nick R.
      Jul 2003
      Anaheim Hills, CA
      Then again it must also be IN the iPod sometimes. Tom's regular iPod doesn't do it in my car but my Touch does.
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by 6'9"Witha69 View Post
      +1
      I did the Zune thing but I hated thier interface for syncing the unit. In other words it was a huge PITA to load and update whereas the iPod is stupid easy.
      Hey, I have a 30gb white one for sale.. low miles and CHEAP!
