View Full Version : Intake temp sensor (Air charge temp sensor) location
My427stang
09-06-2009, 02:42 PM
My Mass flo kit originally had the air temp sensor in the air cleaner.
I am considering either putting it in the plenum or out on the radiator support. I have done both with Mopar Magnum motors in the past.
Only reason is for a cleaner install. Any opinions?
parsonsj
09-06-2009, 03:32 PM
The IAT is used by the ECM to determine the temperature of the air that is ingested by the engine. The closer you can get it to the intake valve, the better, so the manifold plenum is the ideal location.
jp
68Formula
09-06-2009, 04:36 PM
Agreed. X2
GetMore
09-06-2009, 06:31 PM
So, drilling and tapping a hole in the manifold is not a bad idea?
I was contemplating putting a hole in my manifold just under the TB, between where the runners meet the plenum. Wasn't sure if there would be issues.
parsonsj
09-06-2009, 07:42 PM
I drilled and tapped a hole in my plenum directly under the TB. It worked fine.
jp
GetMore
09-06-2009, 11:22 PM
Excellent! Thanks!
