    Results 1 to 13 of 13
      Oct 2007
      ridgefield ct
      c5 wheel centerbore
      what's the centerbore on c5 speedline? (the solid 5 point star) rims? i measured the narrowest part and got 71.1 but researching gives me 72.5 or 72.56, i need to get spacers made up and want to get it right the first time oh, will vette rims (5x120 bolt circle i think) bolt to a standard 5x4.75in pattern?
      thanks
      nick
      work in progress--for the next 10 years.
      1987 monte carlo ss 383ci, 9.7:1, xe274 cam, vortec heads, 200r4, 3.73 posi.
      Oct 2007
      ridgefield ct
      anyone?
      Oregon
      I don't know about the speedline wheel center bore, but the Corvette wheel pattern is 5 x 120.65mm [5x4.75"]. I would trust first hand measurements over anything you've researched online, offline, wherever.
      Tobin
      KORE3
      It's what I does.
      Oct 2007
      ridgefield ct
      thank you. unfortunately i can't trust my measurements more than 1.0mm. i can't get the caliper into the CB itself, so i had to trace the CB and measure that.
      Aug 2001
      Connecticut
      How much time do you have? I have a set, but they are on the car. I do have a set of c5-z06 wheels not on the car but they are at work. -Dan
      1968 Camaro RS/SS, LS7 with Katech mods, T56 Magnum, C6Z06 Brakes
      1968 Camaro RS Convertible LS3/480hp/4L70E
      1962 Corvette 327-340hp stock
      1963 Corvette Split Window Coupe
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Oct 2007
      ridgefield ct
      i'm not in a huge rush. i still have to figure out which rear i'm using, what front suspension, etc. but i'd like to figure it out in the next couple of days/weeks.
      Oregon
      Quote Originally Posted by megaladon6 View Post
      If you've got a machine shop nearby, swing in and see if they'll measure it for you with some inside mics and/or a snap guage. That should get you within a thou or better depending on the tool and user.
      Tobin
      KORE3
      It's what I does.
      Aug 2001
      Connecticut
      ok, I'll be swapping over to my track rims in a few weeks so then it's easy to measure. Otherwise I can pull a rim over the weekend. I have a machine shop so measuring isn't a problem. -Dan
      2006 Corvette Z06
      Oct 2007
      ridgefield ct
      that'd be great! thanks, everyone, for the help.
      nick
      Oct 2006
      Corona, CA
      I show 2.78" as the center bore o.d. for a C5.
      Oct 2007
      ridgefield ct
      that's what? 70.6mm? i have found a 70.8mm spec...
      Oct 2006
      Corona, CA
      Yeah, 70.6 = 2.779" (2.78"). If I were going to build a wheel then, right now, to be hub centric for a C5, I would cut the center bore to 2.78".
      Aug 2001
      Connecticut
      Quote Originally Posted by DriverzInc View Post
      2.78" does sound right, I remember measuring that on the c6-zo6 wheels for ProBell's car. I can double check though. -Dan
      2006 Corvette Z06
