    Results 1 to 3 of 3
      Dallas, Tx
      best way to drop a 69 camaro
      what is the best way to drop the fornt susp. about 3-4 inches on a 69 camaro
      Jacksonville, NC
      I used 2" drop spindles with my 71 monte and hotchkis 1 inch drop springs for my 3 inch from stock drop. The bad thing about drop spindles though is that your backspacing is limited unless you run a wheel 19" or larger up front, I have 20s on mine. The good thing is that it raised my upper ball joint up about 1.5 inches, so it helped my camber curve.
      OK
      easiest and cheapest way would be to de-arch the rear leaf springs and cut the coils off of the front coils.
      here is a link http://www.adfabdesign.com/Illusion/...uspension.html
      Now if you want to go a better route, go air ride and you can change it to whatever you want!
