View Full Version : Ford 9" Rear Axle Vent
69TAPoser
08-21-2009, 10:41 AM
Anyone use this vent from Summit...?
https://static1.pt-content.com/images/pt/2009/08/sume730310-1.jpg
Phil
jknight16
08-21-2009, 11:52 AM
Cool, so that threads in where the fill plug does? I'll be curious to see what people have to say.
Twentyover
08-21-2009, 12:34 PM
Think it goe into a vent port on the top of an axle tube.
69TAPoser
08-21-2009, 01:37 PM
Correct. Mine is 1/8" some are 1/4"
Phil
Hacker Joe
09-12-2009, 09:40 PM
I had one on my car........be careful, they are VERY soft and broke off Very easily.
69TAPoser
09-13-2009, 04:50 AM
Thanks for the heads ups. It's on my car now, but I won't be driveable until Spring. I'll be sure to keep an eye on it.
Phil
Hacker Joe
09-13-2009, 08:47 AM
I broke mine installing it, once it is in I think it would be fine but I would definately keep an eye on it.
wmhjr
05-27-2010, 08:19 AM
Old post - I know. But...
Had no problem installing this last year. Now that the car has been on the road I find that this think spits oil all over the place. It's coming off.
Moser 12 bolt.
Bow Tie 67
05-27-2010, 10:09 AM
The only solution is to get it vented up into the trunk, especially if the car is lowered.
Ron.in.SoCal
05-27-2010, 07:43 PM
Not sure if this confilcts with your post, but Art Morrision makes a puke can that mounts on the floor or trunk pan above the pumpkin. I've never seen anyone use this and I'll look for the link, but I am considering this as an option.
Edit -- Here's the link, middle of the page:
http://www.artmorrison.com/2006cat/48.pdf
Old Style
09-01-2011, 06:35 AM
This is what I have been using for the infamous spitting, it took several failed concepts before I went to the trunk. In a previous comment, he is correct, if you are lower than stock there is no room underneath, at least on an A-body. For reference I am running a 9" with Tru-Trac.
BulldawgMusclecars
10-03-2011, 11:29 AM
The puke can in the trunk is the best solution. I went through this type of vent, as well as the sintered bronze type, on a 4th Gen F-body I used to have. Both puked gear lube constantly.
LS6 Tommy
10-04-2011, 06:59 PM
I used one of these:
https://static1.pt-content.com/images/pt/2011/10/mot14689-1.jpg
Think it'll leak? it's what GM uses for tranny & axle vents.
Tommy
Randy67
10-05-2011, 05:34 AM
Tommy, I used that in my El Camino, no problems in street and autocross use. I didn't do any track days, so I don't know how it would do there.
TheJDMan
12-07-2011, 03:10 PM
I don't have room for a hose fitting on my housing due to the location of a mount bracket. I needed a very low profile vent. I found a stainless steel porous metal on McMaster-Carr item #4456K12. We'll see how it works. If not I will need to weld up the hole and move the vent to the other side of the center section.
Bryce
12-10-2011, 08:26 PM
Google snubber. or an air compressor exhaust....
67w30
04-03-2012, 03:47 PM
Does anyone else have a solution to this problem?
pokey64
04-03-2012, 05:12 PM
https://www.pro-touring.com/showthread.php?87832-II-Much-Fabrication-Fuel-Vent-prototype-installation
LowFast
04-03-2012, 05:14 PM
This is what I am using on my 8.8. Have it mounted high on the rear 4-link cradle.
http://www.summitracing.com/parts/LNG-22569/
Nice kit with quality billet mount. I will have to wait until it is on the road to see how well it works.
scogin918
06-18-2012, 07:29 AM
What thread/nipple size do I need coming out of the axle tube? Right now I just have an empty hole.
TheJDMan
06-19-2012, 01:24 PM
As stated above, you could have either 1/8" NPT or 1/4" NPT.
