    Results 1 to 5 of 5
      May 2007
      Orlando, FL
      Finding 3links in unexpected places
      As I was preparing a new 3link spreadsheet for my site (Page 40), I realized that it could also be used with triangulated 4link and torque arm suspensions. While neither of these are normally considered 3links, if you think of the triangulated pair in a triangulated 4link as a single centrally located link and if you think of a torque arm as being the extended mount for a link having zero length, you end up with...as far as the spreadsheet is concerned...a 3link.
      The spreadsheet then tells you how to adjust the angles of the remaining links so that the driveshaft torque is dynamically cancelled. In other words, for any value of driveshaft torque, the rear tires remain equally loaded. (This is assuming, of course, that they were equally loaded before the launch.)
      This means the fronts lift equally, no preloading is necessary, and the car leaves straight every time.
      http://www.racetec.cc/shope
      san diego
      awesome. I will check it out
      Jul 2009
      canada
      Can this be applied to a handling application instead of a drag only arrangement?
      81 Malibu- work in progress.
      350 sbc, T56, 8.5" Auburn posi 3.42, 4wdb, GW suspension
      and now with unknown seats.
      May 2007
      Orlando, FL
      Quote Originally Posted by 6spdmalibu View Post
      I doubt if a C-Type Jaguar ever found its way to a dragstrip. Seriously, the benefits of dynamic driveshaft torque cancellation are to be sought for any RWD beam axle car when maximum forward acceleration is a goal, whether it is at the exit of a corner or at a dragstrip.
      TN
      Awesome! But I'm still using a three-link.
      Benjamin
      Twin Dusters
