View Full Version : Project "C"
r.a.w.rods
08-17-2009, 06:28 PM
All the kewl project names are taken...lol This is the other truck were doing here at R.A.W. RODS 70 C10 big block truck. The truck started out as a long bed and now is a short bed. My customer already had a short frame to go under it, a new short bed was orders with the wood floor. The truck was bought new by his grandfather and was passed to his dad and them him. He's going with the stock colors orange with a black upper cab and lowering it 4" all around with 18" wheels. Here are the picture as it has come in to the shop.
r.a.w.rods
08-17-2009, 06:32 PM
The rockers are pretty bad so I pulled them off to sandblast and found well more rust.
As you can tell the more I blast the more rust that pops up. Some pretty bad rust were the A/C was mounted.
HILLBILLY68
08-17-2009, 09:50 PM
i'm going to be keeping my eye on this one. This is going to be my next project when done with the 68 again,lol...nice start
r.a.w.rods
08-18-2009, 01:49 PM
Today I got some of the rust cut out of the fire wall and made a few patch panels.
Here's the patch I made for the firewall
Filled the hole in the cab for the gas neck. It will be moved under the bed.
Heres what was behind the outside cab corners.
Test fitting the new panels.
Draginutz
08-18-2009, 03:57 PM
I will be watching this...my 72 long bed is next after my 63 Chevy II
r.a.w.rods
08-19-2009, 11:48 AM
Got the cab corners on and started welding the new panels in place.
Just checking the fit for now.
Also had to replace part of the supports under the cab.
After getting both sides done I blasted the bottom.
Next I'll start Installing the Rocker's
brrymnvette
08-19-2009, 06:52 PM
Love it. I love these trucks. This will be my next build after my current one....hopefully.
MuscleRodz
08-19-2009, 07:46 PM
Been there done all that on my 69 Blazer. I hope to get back on it after SEMA
Motown 454
08-19-2009, 09:29 PM
Nice fab work on the firewall . its a nice project.
HILLBILLY68
08-19-2009, 11:55 PM
so what kind of blaster are you using?
r.a.w.rods
08-20-2009, 05:37 AM
Its a EMPIRE Presser Blaster. Works great if you have the Air Compresser to support it. I can run this thing for 1 hr with a 100 pound bag of Black Beauty Sand. I have one of there big cabinets too and love it.
https://static1.pt-content.com/images/pt/2009/08/P150-1.jpg
MarkM66
08-20-2009, 07:12 AM
So that type of sand is okay on large body panels? What pressure do you run to it?
Will it take undercoating off?
r.a.w.rods
08-20-2009, 11:19 AM
Some undercoatings are a pain to get off. Most of it on this truck came off pretty good but there was a lot I had to strip off by hand then blast. They make stuff to spray on undercoating to get it off but I like heat and a sharp blade or you can use a wire wheel. As for how much pressure, I go around 110 psi for frames and things that I know will not warp, but for fenders cab's I turn the presser down and dont blast on one panel too long. If you do your heading for trouble. After blasting we still go over the metal with 80g paper and then DP90. I really didnt want to spend the money on one but now Im glad I did. Now I dont have to hurt my fingers in the hard to reach places. I asked the guy about the sand and said it was fine to use and is safer for your lungs( STILL WERE A FILLTERD MASK). DO NOT USE PLAY SAND like at lowes I know people do but dont. When you go into a place that sells this kind of stuff they will have all kinds of sands for you to look at for what your doing. I hope this helps you out.
r.a.w.rods
08-20-2009, 11:27 AM
Well I have the rockers on for good now. I used plug welds just like stock, really makes a clean look when primed.
Primed In DP90.
HILLBILLY68
08-20-2009, 02:32 PM
looking good
icebird84
08-20-2009, 02:39 PM
looking good
indeed
1971CHEVELLE
08-20-2009, 03:26 PM
Awesome looking very good keep us posted
Draginutz
08-20-2009, 04:08 PM
Don't know what your plan is for the gas door but, I worked at a shop where we used a gas door and arm (from a 90s something) and cut it down to bolt behind the left bed side marker ligh. Put a blazer tank under the bed and used a early model blazer inner tube cover in the bed to "hide"0 the tubes and such. wish I had pics it work out pretty slick. We also used one of those gas caps you don't have to take off, it has the little door built in. Anyway just a thought and rambling. You are haulin on this truck. Are you taking a break from the ford?
r.a.w.rods
08-20-2009, 04:18 PM
The Ford is waiting for the A/C to come in, so parts are getting block sanded. My customer is using the blazer tank and wanted to put the gas door in the tail light but went with a floor mount cap in the bed. Im using the gas cap that has the trap door on the Ford.
Thanks guys I should have some more pictures tomorrow.
Nice work. One day I hope to weld that nicely. Keep it up.
Code Red
08-21-2009, 03:42 AM
awesome work, yeah I tried the play sand from lowes with a small blaster from harbor freight it sucked ass LOL
r.a.w.rods
08-21-2009, 02:36 PM
LOL.....I think we all have tired it one time or another....lol
Well the Floor is undercoated and painted. I also got the new short bed panels in.
Here are the new bed sides.
Billetmaster
08-21-2009, 03:32 PM
I love those trucks...I am hating you right now :)
r.a.w.rods
09-04-2009, 02:47 PM
Bed went together pretty good. Some of the holes had to be redrilled to get the side to line up but thats it. Made a cart to set the bed on and got it in some primer today.
DP90 laid down
So the sides of the bed only screw on in the front or is that all the way around?
r.a.w.rods
09-06-2009, 06:12 PM
All the way around on the c10's
tones2SS
09-07-2009, 08:05 AM
Looks good!
wickedred
09-07-2009, 08:35 AM
Should make for a super nice C10 when finished. My first ride was a 69 SWB CST. I have owned several since then, and have been contemplating selling my 70 Camaro Project again to buy another C10.
r.a.w.rods
09-07-2009, 04:18 PM
Here are a few shots of the frame. This truck was a long bed but we found a short frame had it blasted and powdercoated. As you can see the redone 402 big block is in and a few upgrades to go with it.
Very clean and detailed. Nice!
Sounds like having screw on bed panels makes for quick change outs for rust. Not a bad idea if you ask me. Are there downsides though?
r.a.w.rods
09-07-2009, 06:38 PM
No downsides at all. Even the stock bed is bolted together, but instead of using the old hex head bolts I Installed S.S. button heads for a clean look.
srh3trinity
09-07-2009, 08:01 PM
The frame/engine looks nice and clean. I have always liked those valve covers. This is shaping up quite nicely.
r.a.w.rods
09-24-2009, 03:27 PM
sorry im slow with pictures, still sanding away. Seems like the small stuff takes the longest.
Draginutz
09-24-2009, 03:35 PM
Coming along nicely. Always awaiting more pics.
r.a.w.rods
09-25-2009, 01:44 PM
Bed is on and fits really well. Ive been really happy with the after market panels. I had to put a 1/8in shim on the passanger side of the cab to get the lines right, but for now it looks great. Looks like the new B.B. valve covers are going to clear and Ill be using a smaller power booster so looks like its good to go.
colt zantop
09-25-2009, 03:16 PM
cool project..I would like to build a 68...looks like its coming along good! nice work!
r.a.w.rods
10-17-2009, 04:33 PM
I ment to post this up earlier but just didnt have time. Ive started hanging the front metal to see how every thing is going to fit. Were going to stop at this point so we can finish pulling the 63 f100 apart for paint.
