    Results 1 to 8 of 8
    Thread: Hard to Handle
      Aug 2009
      Hard to Handle
      Are power steering boxes any better than manual boxes in terms of road feel?My bro has manual box that he got out of a parts car(70 SS camaro)that i can have and put in my 81Z28
      Feb 2008
      Sesser, Il
      Is this a track car, occasional street car, or daily driver? Personally I don't care for a manual box in a street car. Maybe I'm getting lazy in my older age but the constant turning of city driving is too much of a chore. I don't know about road feel but I believe a manual box has a slower ratio to make up for the increased effort to turn the wheel.
      If you wanted to go with a used steering box, look for a mid to late 80's IROC box with 16" wheels. Look for code XH on the round part of the end. These have a higher road feel than the 15" wheel Z/28's (supposedly coded YA?) and the regular f-bodies. I've heard these will bolt on to a 1st gen and so should also bolt into a 2nd gen.
      Doug Gulley
      66 C10 383, AFR 190, Accel SuperRam, Hyd Roller 230*/236* 280XFI, aftermarket T56, *under construction*
      Aug 2009
      The 12:1 box from 85 up iroc is a direct swap on an 81. Just did it myself.
      Feb 2008
      Sesser, Il
      I've got one on my 86 Cutlass and I love it.
      Doug Gulley
      Aug 2009
      it`s for the occasional track outing and some weekend driving.it`s comes free,thought i could take advantage of it.
      Feb 2008
      Sesser, Il
      If you don't mind tugging on a manual box, then I'd say go for it. For the investment you'd have in it, you could swap it out later if need be.
      Doug Gulley
      Aug 2009
      I think the shaft on the 70 is different size from steering shaft on the 81. You might want to check that.
      Loganville, GA
      The steering shaft (input shaft) is smaller on the 81, it is the same as the manual steering box (uses the same coupler per some suppliers).
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
