Results 1 to 7 of 7
Thread: Turning down axle flange
03-31-2005 #1
I am about to install the Baer Touring setup on my 12 bolt. For those who have turned their axle's down to fit the rotor, how did you do it? Lathe or garage version(car in gear, grinder in hand)?lol
Does it have to be perfect or are the studs holding the rotor centered?
OOps move to brakes if neededDean
69 Camaro 355-3.73 Moser Truetrac-TKO600-Hotchkis-DSE-QA1's-Baer's-17"Budnik's
ST U/LCA's-GW Del-a-lum's-Lee p/s
03-31-2005 #2I took mine to a machine shop and had them turned down for $13.75. The studs do keep the rotor centered, but considering the money and time invested I preferred to have the flanges machine.
03-31-2005 #3For my TC rear discs I took my axles to a local machine shop. I had the flanges turned down ~1/8" and also had the center hubs turned down ~1/32". Other than time it cost me $20.
There's a decent amount of extra slop in the rotor holes for the studs, so the center hub has more to do with keeping everything centered in my opinion. I mic'd everything and had them turn down the center hub as little as possible. Just enough to get the rotor to slide over.
Dan
03-31-2005 #4
