    Results 1 to 5 of 5
      Washington, MO
      Need Some Help Finding Tires!!
      I'm kind of shifting themes with my driver (86 C10 short bed). Currently I have 285-60-18 on an 18x8 wheel and I'm not crazy about the setup for multiple reasons.
      Now what I'd like to do is shift more toward a 'Nascar' type of look/stance with the new setup. I want to build this setup around the tire size to nail down the overall look (short/stocky/wide). But this can be tricky with a full size C10 short bed. I don't want to get the 'elephant on roller skates look'.
      So currently I have a 31.5" x 11.73" tire. I want to go shorter and wider but am having trouble finding a good size. (The wheel size should be between 15"-18" diameter and 9-10" wide, but it's not important at this time). I'd like to find a 28-30" tall tire and at least a 12" total section width. And they should be street oriented tires. Once I get the tires nailed down I'll find the right wheel to go inside.
      Thanks in advance for any help!
      If you go to www.tirerack.com you can view tire specs all day long. They will provide recomended rim width, rim width used for measurements, diameter, width etc.
      For example, I plugged in your 285/60/18 then hit specs on the BFG KDW that came up. It then lists specs for that specific size, but then goes on to list all sizes/specs available in that model.
      http://www.tirerack.com/tires/Spec.j...omCompare1=yes
      Here's a 295/50/16 that's close to your requirements 12.2" sect width & 27.6 diameter:
      NY
      Also if you look on Tirerack and other sites they are blowing out the Victory aluminum nascar looking wheels. I think some are as low as $70 each. I am sure with some adapters you would be good to go.
      By the way I have Aero wheels on my wagon and 2 had to be returned as they couldn't be balanced and the ones that are on the car have a strip of weights about 6" long. They are lighter than say Cragars but there are trade offs.
      Washington, MO
      With that glaring review for Aero I think I'll pass! I'll have a look at the Nascar wheels though..
      The problem with 15" wheels is that the tire selection sucks of course. I'm am doomed to a 275/60 or a 295/50 so I am thinking about running a 295 50-16 on all for corners. Thats 27.6 x 12".
      So I am going to look for a couple options in a 16x10 wheel.
      Washington, MO
      I really like the Basset Wheels... so much that I might run a 295/50-15 at all fours.
      Unless anyone has any ideas for a 16x10 wheel in a 5x5 lug pattern.
