View Full Version : Need Some Help Finding Tires!!
Tony_SS
08-12-2009, 05:59 AM
I'm kind of shifting themes with my driver (86 C10 short bed). Currently I have 285-60-18 on an 18x8 wheel and I'm not crazy about the setup for multiple reasons.
Now what I'd like to do is shift more toward a 'Nascar' type of look/stance with the new setup. I want to build this setup around the tire size to nail down the overall look (short/stocky/wide). But this can be tricky with a full size C10 short bed. I don't want to get the 'elephant on roller skates look'.
So currently I have a 31.5" x 11.73" tire. I want to go shorter and wider but am having trouble finding a good size. (The wheel size should be between 15"-18" diameter and 9-10" wide, but it's not important at this time). I'd like to find a 28-30" tall tire and at least a 12" total section width. And they should be street oriented tires. Once I get the tires nailed down I'll find the right wheel to go inside.
Thanks in advance for any help!
bretcopsey
08-12-2009, 06:41 AM
If you go to www.tirerack.com (http://www.tirerack.com) you can view tire specs all day long. They will provide recomended rim width, rim width used for measurements, diameter, width etc.
For example, I plugged in your 285/60/18 then hit specs on the BFG KDW that came up. It then lists specs for that specific size, but then goes on to list all sizes/specs available in that model.
http://www.tirerack.com/tires/Spec.jsp?make=BFGoodrich&model=g-Force%20T/A%20KDW%202&partnum=86VR8GFTAKDW2RF&vehicleSearch=false&fromCompare1=yes
Here's a 295/50/16 that's close to your requirements 12.2" sect width & 27.6 diameter:
http://www.tirerack.com/tires/Spec.jsp?make=BFGoodrich&model=Radial%20T/A&partnum=295SR6RADTA2&vehicleSearch=false&fromCompare1=yes
BRIAN
08-12-2009, 07:59 AM
Also if you look on Tirerack and other sites they are blowing out the Victory aluminum nascar looking wheels. I think some are as low as $70 each. I am sure with some adapters you would be good to go.
By the way I have Aero wheels on my wagon and 2 had to be returned as they couldn't be balanced and the ones that are on the car have a strip of weights about 6" long. They are lighter than say Cragars but there are trade offs.
Tony_SS
08-12-2009, 06:12 PM
With that glaring review for Aero I think I'll pass! I'll have a look at the Nascar wheels though..
The problem with 15" wheels is that the tire selection sucks of course. I'm am doomed to a 275/60 or a 295/50 so I am thinking about running a 295 50-16 on all for corners. Thats 27.6 x 12".
So I am going to look for a couple options in a 16x10 wheel.
Tony_SS
08-15-2009, 12:44 PM
I really like the Basset Wheels... so much that I might run a 295/50-15 at all fours.
Unless anyone has any ideas for a 16x10 wheel in a 5x5 lug pattern.
