View Full Version : teflon heim joints
pav8427
03-29-2005, 08:14 PM
teflon heim joints and spherical bearings are designed for
'lube free' operation.
if a person wanted that extra insurance for those high buck ends
what grease would be safe to use?
thanks, doug
jeffandre
03-29-2005, 08:54 PM
I used Red Line wheel bearing grease on my Herb Adams sway bar spherical rod ends with great results so far. There may be a specific grease so hopefully someone with that knowledge will chime in.
03-29-2005, 11:11 PM
The trick would be to keep dirt out of the joint or the grease will collect it. There are circle track seals for them.
jeffandre
03-30-2005, 12:26 AM
I will look for those when I get my front end finished up!
quadfather
03-30-2005, 05:23 PM
the reason they have teflon liners is so you don't have to lube them . teflon is self lubricating .plus the liner does a good job sealing out the dirt. just try to keep them clean and if you have to do something just a little wd-40 works great.
jeffandre
03-30-2005, 05:49 PM
I recall reading somewhere that the teflon one's require more frequent replacement, but I can't remember where I read that... Some may be rebuildable???
Ripper
03-31-2005, 12:32 AM
Available from speedwaymotors, ridiculously cheap! :jump:
quadfather
03-31-2005, 03:10 PM
i woulnd't use teflon rod-ends they are junk. but rather use teflon lined rod ends theese are the best quality r-ends you can buy .we use them if all our race cars .a standard 3/4 by 3/4 c-moly r-end runs about $35.00 not like the cheepo's that use the teflon as a bearing race.instead of just a liner.
Ripper
04-01-2005, 12:02 AM
I meant the seals.. They are ridiculously cheap... I get it that it's not a good idea to use cheapest rod end available.
Fluid Power
04-01-2005, 11:29 AM
We sell FK rod ends, used by anybody in racing, drag, road, etc. The quadfather is right, we sell the super heavy duty 3-piece with a ptfe liner to all sorts of race shops in town. $35.00 is about right for 1 of these 3/4 x 3/4 ends. We never replace them because they have failed. The static load on the 3/4 x 3/4 is 28,090 lbs!
Darren
pav8427
04-01-2005, 05:15 PM
these are the style of rod ends i am using on the front a-arms i have
on my chassis. i am also using 1" ID sperical bearing with S.S. housings
for my rear lower control arms.
i havent been able to find a source for 1" bore seals.
i found some grease intended for 10,000 rpm moulders at work, but it runs around $85 a tube.
doug
Fluid Power
04-01-2005, 06:24 PM
Pics? got part numbers? I will call FK on monday and see If I can come up with seals for ya.
Darren
