View Full Version : New wheels on the 70
brownz
07-26-2009, 05:31 PM
Got some CL205 wheels for the nova and thought it would be cool to show what it looked like when i got it after sitting for 24 years to now. i have been driving this car as a daily driver all year and I cant really do alote to the car as it not my main project yet so it just small steps until the camaro is done.
I know ppl love specs. i when safe on them so i could drive it.
18*7 front with 4in b/s for the drop spindles and disc brake i will be putting on.
235/40
rear, 18*8 5.25 b/s 255/45
let me know what you think.
https://static1.pt-content.com/images/pt/2009/07/100_0307-1.jpg
https://static1.pt-content.com/images/pt/2009/07/100_0362-1.jpg
BonzoHansen
07-26-2009, 05:32 PM
Big improvement. Adding round tires is a plus too, lol.
2008fx4
07-26-2009, 05:55 PM
looks great!!! its amazing what the correct set of wheels can do for the look of a car!
street3285
07-27-2009, 06:25 AM
Looks great.... what a difference just the wheels and tires make.
jy211
07-27-2009, 06:45 AM
The simplest of mod's! :idea::1st:
oestek
07-27-2009, 07:16 AM
Great choice! Looks killer!
brownz
07-27-2009, 04:57 PM
Thanks guys. yep you can put a good set of wheels on anything and make it cool.
tones2SS
07-27-2009, 05:25 PM
Looking good man!
6'9"Witha69
07-27-2009, 07:21 PM
Looks good!
They were only flat on the bottom!
Not puke green 71
07-28-2009, 01:36 PM
I really like the look, Question? what drop spindles do you have? and could you fit wider wheels up front? Thanks Eric
69LT1Nova
07-28-2009, 02:10 PM
x2!!
Do you think you could have gotten away with 8" wide rims? Do you have pictures from front to back and back to front? I'm interested to see how the tires sit on the rims, and how the rims fill out the wheel wells.
brownz
07-28-2009, 02:12 PM
http://www.nnnova.com/. i dont see them on the web site? i got them used from a member on a nova forum. i called nnnova and they said that you can run a 8in wheel with 4.5bs. I have heard that it may ot may not hit the wheel. ( the steering arm) so i went the safe route with the 7in wheel. and its not like you can get alote more tire in the front than a 235.
69LT1Nova
07-28-2009, 02:14 PM
Ain't that the truth. I tried out a 245/45/18 just last week with 4.5" BS. Nope... didn't work. :hammer:
PleaseNoSteve
07-29-2009, 10:46 AM
Damn dude - that looks awesome!!!
strtlegal
07-29-2009, 05:28 PM
LMAO....Isnt that 26+" tall??
try a 245/40. its just a little taller then a 235 but is just a hair wider. Problem with some 235's is if the back isnt low enough and you pair it with a 275 in the rear it looks like a rubber band.
You can get away with 5" bsp(8") if your creative with the steering arms. If not its nothing a little negative camber wont take care of.
Worst fitment on a lowered nova is 7" w/4" bsp, even with a skinny wheel. nothing like stuffing your tire into the fender wheel bolt.
brownz
07-29-2009, 05:34 PM
I have a question. you say that the 7in wheel with 4in bs will hit the inner fender bolt? it looks like i will have enough room? with the sagging springs the tire is just about at the lip and its not close at all.
have you had this issue?
strtlegal
07-29-2009, 08:01 PM
Figure lowering your car another 2". I know the 2" drop spindle lowered some but when I say low Im meaning the fender covering the tire like the rear.
and yes I had that issue with just a hair taller tire.
brownz
07-30-2009, 02:00 PM
it looks like i will need to replace the front springs when i install the drop spindles and disc brakes. cuz the front is all stock in the pic and ya another 2in would be a problem.
69LT1Nova
07-30-2009, 02:36 PM
26.7"... YEP! :hammer: :hammer:
try a 245/40.
Trying out the 245/40s today, wish me luck! Good thing I had some junk ones sitting around on spare rims. :) They measure out at 25.7"... we'll see what an inch of diameter does.
What's up with the steering arms? Do they just need to be modified, or does the tie rod hit with a 5" BS? I'm running aftermarket control arms with adjustable bump stops... and 2" drop springs...
strtlegal
07-30-2009, 08:54 PM
It barley rubs it at full suspension cycle, however a nice thick SAE washer between the knuckle and the arm will fix your issue if any
WILWAXU
07-30-2009, 09:44 PM
Looks good!
69LT1Nova
07-31-2009, 07:50 AM
MF'er!!!!
:machine: 245/40/18s with 4.5" BS on a 8" wide rim still rubs!!!!
:hammer: :hammer: :hammer:
I'm sick of this chit. I'm going to have to go to a 18x7 rim with like a 235/35/18 tire. Would bumping up the BS to 4.75 or 5 get rid of the rubbing on the back of the wheel wells?
Time to break out the Wheel Right yet again... grrr....
buickfunnycar.com
07-31-2009, 10:44 AM
MF'er!!!!
Where's it rubbing?
Have you tried removing the top inner fender bolt..?Sometimes,that little bit will do the trick,if your suspension is nice and firm.
4.5" of b/s is right on that razors-edge of not working,4.75" is a much better call...and 4.875" is even better.:yum:
69LT1Nova
07-31-2009, 11:53 AM
I'm running with the fenderwells (have to... live in the Northwet). Its rubbing on the back of the fender well, on the outermost edge. Let me take pics and post 'em.
FYI - I'm switching to a button cap screw instead of fender bolts. Just bought them today.
strtlegal
08-01-2009, 10:05 PM
LOL...It will rub even if you go to a button cap, once the suspension starts cycling its all over with..
You maybe able to run a degree of negative camber, but it will still catch on the backside..
Just buy my Budniks thats are 5.5" bsp and run a spacer to compsensate for the tie rod area and it will fit..
$1000.00 rims and tires..lol
69LT1Nova
08-03-2009, 07:12 AM
Instead of taking over this thread, :) I'm starting a new one that pretains to my issue... FYI.
brownz
08-03-2009, 02:03 PM
haha no big deal, just hope you get your issue worked out.
OnEdge
08-13-2009, 06:53 PM
Those wheels look awesome. Those are the wheels that I'm planning on using on my 72 Nova.
formula
08-13-2009, 09:24 PM
i absolutely love love love the way the patina of the paint goes with those wheels dude. Way too cool. Keep it like that! Rock the **** out of it!
