    Results 1 to 2 of 2
      Jun 2009
      MSD in a 72 Olds
      Where is a good place to pull 12 volts for a MSD box on my 72 Olds. I'm canning the points and I was wondering if I should go straight off the ignition switch on top of the column. Isn't that wire that goes to the coil a resistor wire? I don't want to go off the ignition terminal on the fusebox. I need 12 volts switched for the box and coil.
      Sunny Florida on the Suncoast
      When I did the MSD 7M box in my 71 Monte Carlo years ago I pulled the Ign for the box direct off the ignition switch. The wire to the coil in the factory harness is a resistance wire and will deliever only 8 volts in run. I would not go off the fuse box for the ignition because all the ports there are fused, so you could be at the side of the road with a dead car and a blown fuse.
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
