    Results 1 to 12 of 12
      Jun 2009
      Sacramento Area
      Tires for 17x9.5 Wheels
      Here’s my dilemma. I have a ’72 Chevelle (soon to have Hotchkis 1” drop front/rear springs) and want to put some 17x9.5 wheels on the rear (already have the front setup down). What tire will fit this wheel that is in the 27” to 27.5” diameter range? I can’t seem to find any. I’ve seen 275/50/17’s (Nitto and Falken), but those are made for trucks/suv’s and that’s kind of a weird size.
      I know there’s probably some drag radial tires out there with the size I need. The only thing about DR’s is the tread life (not long at all). I’ll take some suggestions if any of you have them.
      Jul 2008
      Bethlehem PA
      To get some ideas, go to TireRack.com and do a search by tire size, search for "all available sizes", and enter 17". Shows all sizes they have available. Lots of options.
      John at SC&C
      Savitske Classic and Custom
      NEW # 610-381-6100
      '87 Buick Regal Turbo T - Since New
      Lots of SC&C, Fays2 Watts Link
      Boze Pro Touring wheels,
      Baer 13" Pro+ & SS4+
      Shaved door handles
      Custom S/S Exhaust
      Aug 2001
      Connecticut
      I run a 255/50/17 on the rear on 17x9 rims, 27.1" dia. It's a size that was used on the mustangs I believe- BFG-KDWS and Nitto NT555 both have them. -Dan
      1968 Camaro RS/SS, LS7 with Katech mods, T56 Magnum, C6Z06 Brakes
      1968 Camaro RS Convertible LS3/480hp/4L70E
      1962 Corvette 327-340hp stock
      1963 Corvette Split Window Coupe
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Eastern Virginia
      I have 275/40/17 but that calculates out to a little over 26"
      Scot
      86 Monte SS
      Southern Nevada
      Quote Originally Posted by sn75 View Post
      http://www.mandhtires.com/store.php?...on=show_detail
      28" Diameter. I can't imagine seeing these on the front of a car, though.
      1969 Chevelle SS396
      Currently figuring out more ways to make simple tasks difficult.
      Build thread...
      --Dan
      Aug 2001
      Connecticut
      Quote Originally Posted by GenPac View Post
      I have these for drag tires, they are kind of mis-sized, they are really not any wider than the 255/50/17 street tires, I can check they are all of the 28" tall too, I have to raise my coilovers. A side note, they don't hook up that well either. The m/t's were backordered so I went with these, bad move.
      2006 Corvette Z06
      Jun 2009
      Sacramento Area
      The 255/50/17's might work. They would be stretched a bit on the 17x9.5, but I don't think it's anything outrageous to put them on this size wheel (similar to guys running 275/60/15's on 15x10 wheels).
      As for the M&H drag tires, probably not going to go that route (due to the increased wear due to soft compound).
      Jun 2009
      Sacramento Area
      Let me know what you think of this combo.
      Front 17x8 with 255/45/17 (26.04")
      Rear 17x9.5 with 255/50/17 (27.04")
      Think that will look ok? The 245/45/17 is under 26" and I think it would look too small (just my thought).
      Chicago
      Too big for the front. What about some 235 45 17 ?
      Jun 2009
      Sacramento Area
      Hmm, probably the 245/45 will work then. The 235/45 are still not tall enough. Remember, I'll be 1" lower (or thereabouts) in the front from stock height once I install my Hotchkis springs.
      Sep 2007
      Livermore, Ca
      why don't you go wider in the rear? I'm running a 295/45/17 on a 17x9.5, and it sits at about 27" tall.
      Aug 2001
      Connecticut
      the fronts on mine are 245/45/17 on 17x8. (as mentioned above, the rears are 255/50/17 on 17x9)
      I like that 295/45/17 though, and with an a-body you should have room enough if you get the rim/backspace right. (if you can get them in a street tire - those are m/t if I'm reading the post right?)
      - Dan
      2006 Corvette Z06
