Results 1 to 13 of 13
06-24-2009 #1
- Join Date
- Jun 2006
- Location
- Halden, Norway, Europe
- Posts
- 213
wheel/tire to wheelwell clearances, 64 chevelle
Hi,
I'm trying to fit C5 corvette wheels on my 64 Chevelle. The front is working out ok with correct spacers but the rear seems a bit tight. The C5 rear is 275/40R18.
I have cut away the fender lip and lightly massaged the inner wheelwell with a hammer to bend it somewhat inboard.
What kind of clearances should I have at a minimum towards the inner frame/wheelwell side and the outer fender lip? It depends of course with how much suspension travel I've got with the drop springs (approx 150 lbs) in there now.
The problem areas seems to be the top of the wheel hitting the inner, upper wheelwell and at the passenger side the rear part of the wheel scrubs the fenderlip. I have measured and the axle is pretty much perfectly centered but I guess the body could be somewhat misaligned with the frame.
06-24-2009 #2
- Join Date
- Jun 2006
- Location
- Indianapolis,IN
- Posts
- 1,605
1/2 inch clearance. is what we shoot for.
06-24-2009 #3
- Join Date
- Jun 2006
- Location
- Posts
- 213
Thanks, I'll aim for that as well, a little more if I can get it, but it's tight in there...
06-25-2009 #4
