View Full Version : 68 Camaro - rear shock relocation options?
whytry
06-20-2009, 03:30 PM
I have seen the BRP setup and the Competition Engineering setup and the Chassisworks setups and all the them pose the problem of exhaust routing in the factory location.... I have 3" exhaust in the factory location and its all mandrel bent, and I want to keep it and not be forced into going back to turndowns... I want to relocate the shocks inboard for more tire clearance on my stock wheel wells and I have seen and read about options and they are all about the same. I wanted to see if there is a chance of using a set of stock upper shock mounts like the factory ones here:
http://summitracing.com/parts/GMK-4020-724-67/?image=large
I would simply mount them in the trunk and use my existing shocks and use the Caltracs inner mounts... Would that work? I can then put the shocks anywhere I want correct, thus not interferring with my 3" mandrel bent exhaust......
I am looking at running an 18x10 in rear stock wheel wells, more on this in the wheels/tires forum... This would give me the ideal setup and the shocks would not rub the tires..
Opinions, thoughts, etc?
blown69nova
06-20-2009, 05:54 PM
Look at smith racecraft, I'm using their relocation kit on my Nova. The best setup out there in my opinion.
06-20-2009, 07:44 PM
I know what you are looking at (Goodmark link) but those are thinner than the 1/4" plate that is welded to the trunk/frame pan. You can cut and relocate those if needed.
However....
The shocks a should not pose a problem when running rims larger than 16". Your interference will come from the leaf spring and wheel tub itself.
What was your BS again?
neki67
06-21-2009, 12:37 AM
I'm running 17x10 on my 67 with the shocks in the original location. I did massage the inner fenders and did some cutting near the stock mounts but I did not touch the mounts. No rubbing.
whytry
06-22-2009, 10:59 AM
Cool, this is a big help, thanks guys. I was hoping I wouldn't have to relocate, I know on 15x9 with 275/60 drag TA, I had the shocks rub the tires... So since I am increasing the rims to 18's I should be good.
Hey Vince I am looking to go to a 5" BS on a 18x10 with my rearend shortened by 3 1/4 with willwood discs, this should allow me to have the wheels still centered and leave about 5/8" on either side on the tire.. For the leaf spring interference you are referring to the rear of the leaf correct?
