Mr Nick
06-20-2009, 03:23 PM
I'll be receiving my front and rear C5/C6 kit from KORE3 next week.
Going to install a manual master cylinder from 76-77 Malibu, adjustable proportioning valve, line lock, and all new hard lines at the same time.
I want to make sure we hook everything up in the proper order, as my car currently has a combination valve installed... this things will be different.
From front reservoir on MC (rear brakes) hard line down to the frame rail, install adjustable proportioning valve, hard line along frame rail to cross member above axle... and so on.
From rear reservoir on MC (front brakes) hard line to line lock, hard line to "T" fitting, then off to each front caliper...
Sound right?
Do I need a residual valve anywhere? If so, why?
Why do some brake systems have the hard line in a coil right after the MC? Should we do that?
What type of brake fluid should I use?
Lastly, feel free to post pics of your install, I might want to copy it!
Nick
https://static1.pt-content.com/images/pt/2009/06/wil2608419_cp-1.jpg
https://static1.pt-content.com/images/pt/2009/06/55563000-1.jpg
Sound right?
Nick
