    Results 1 to 9 of 9
      Melbourne, FL
      Straighten/flatten coil lines ???
      Not sure where the best place is for this question so I'll start here. I hope to start runnign fuel and brake lines on my car soon. The brake likes are stainless and the fuel is alum. Both are coiled. What's the best way to straighten/flatten them out prior to running them down the frame??
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Jun 2001
      Orlando, FL
      I never could get mine straight. I tossed them, and bought straight lines.
      jp
      ​John Parsons
      Midwest
      It's tricky, but it can be done. I can't explain it... maybe it's a good video how-to topic..
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Dunwoody, GA
      roll it out onto the floor. That will get it mainly straight. It's not easy to get it 100% straight though.
      Trey
      ~ Jon Hammond
      Florida
      I bend one end out enough from the coil to stand on the end of it. Then stand on the end and roll it forward while walking on the tubing thats on the floor and applying pressure to the roll against the floor as you roll. It comes out pretty straight with a mild bend from that. Once you've got a long enough section from the roll cut it off. Then to get out the mild bend hold the tubing out as far as you can reach on both sides of your body and pull it back against your stomach using yourself to bend against. After you play with it a bit you'll see you can make it appear almost perfect.
      Melbourne, FL
      Thanks for the tips. What's the current consensous on using all braided lines and no hard lines. And I would only use hoses that had the ends factory installed. Not ones that I would assemble by hand.
      Manteca, CA
      One of the brake line companies makes a small tool that does it...I cant remember who....... I have the brochure at home. It looked like a small version of the hydraulic machines that fab shops use to bend pipe etc
      The other way I saw on Musclecars was the take a block of wood and use that to roll the piece back and forth on the floor
      Manteca, CA
      Feb 2007
      Vancouver, WA
      Quote Originally Posted by 67 455 Bird ragtop View Post
      I prefer regular steel hard lines. They aren't terribly glamorous, but they are very durable and reliable. You can shine them up and clear them if you are after pretty. Stainless is nice stuff, but a bitch to flare. Lots of the braided stuff still has rubber line under the braid, except now you can't visually inspect the rubber. Plus, the steel braid is a teriffic dirt trap and winds up looking funky if you drive the car a lot.
