View Full Version : 69 Camaro Master Cylinder
JEFFTATE
06-12-2009, 12:18 PM
I plan to put an upgraded 4 wheel disc setup on my car.
But , for now I need to replace the stock master cylinder on my '69 SS Camaro.
The car has stock front discs and stock rear drums.
It has one of those master cylinders with the bleeder screws made into it above the brake line fittings .
I was gonna' get a new master cylinder , but every catalog I look in shows several choices.
Like:
Exc Z28 , with front drum brakes.( 4 wheel drums )
and
Exc Z28 , with front disc brakes. ( Front disc / rear drums like an SS )
and
Z28 ( 4 wheel disc ???? )
So , my comment is :....
I thought there was only one master cylinder for disc/drum and one master cylinder for drum/drum.
So I'm guessing the "Z28" master cylinder that the parts stores are carrying is for a car with 4-wheel discs ????? ( Like the JL8 option)
But , not every Z28 had 4-wheel discs.
Most Z28's had disc/drums just like an SS.
Am I right ??
Am I missing something here ????
Tito
06-12-2009, 07:49 PM
Not 100% sure, but everyplace I've seen that has a unique Z28 master cyl suggests that the Z28 used a Bendix brake booster versus the Delco/Moraine booster used in "everything else".
Not sure if there's something different with the Bendix booster that specifically requires a different master cylinder (pushrod hole? bolt spacing?) or if it's just a different setup that was used.
ProdigyCustoms
06-13-2009, 07:09 AM
Buy the Z28 Disc / Drum master.
JEFFTATE
06-13-2009, 04:22 PM
Thanks Guys
