    Results 1 to 6 of 6
      Oct 2008
      Willwood stud size larger than stock??
      I just installed a set of 13" rotors and 6 piston calipers on my 69 Camaro. The studs on the spindle are larger than my stock lugs. Anyone know what Willwood uses for stud size? Thanks.
      Jan 2000
      Thousand Oaks California
      1/2"-20? Any chance you have a caliper?
      Larry Callahan
      Oct 2008
      Quote Originally Posted by Larry Callahan View Post
      I don't. I may have to take the spindle into the tire shop and get them to check it. I was hoping somebody might know off hand.
      grab a 1/2" open end wrench and see if it fits snugly over the stud.
      if the 1/2" wrench is too big, then try a 12mm.
      they are probably 1/2"- that's the standard upgrade stud size for GM cars.
      Aug 2003
      Orlando, FL
      Larry is correct. They are 1/2" X 20
      So. Cal.
      Yup, I just threaded my wilwood studs in today and thats what they are. If the thread through the back of the hub then they are correct. JR
