View Full Version : Power Door Lock not working
paulk68
05-27-2009, 02:33 AM
hey guys, my wifes 06 malibu driver's door lock will not work with the power lock/unlock button. is this an easy fix?
thank you
MonzaRacer
05-27-2009, 02:45 AM
depends this car runs through the BCM (body control module) if you can get switch/panel out and test switch with volt/ohm meter for proper operation, other wise honestly ttake it to a good technician as it may require a scan tool, if you want I can email you the 3 door lock diagrams but its pretty intense even for me and I AM a tech.
Good Luck
Lee Abel
AFTERMARKET PERFORMANCE
paulk68
05-27-2009, 02:56 AM
Good Luck
Lee Abel
Thank you very much Lee. Iwill take it to my local gm dealer they are good people.
