View Full Version : One wire alternator overcharging battery
69Zman
05-24-2009, 09:02 PM
One wire alternator overcharging.
I have tried two different powermaster alts and have a brand new battery, checked all connections/ grounds etc and still sending 17v to the battery. Any ideas here? thanks
AJSZR2326
05-26-2009, 11:17 AM
check your voltage regualtor, but alternator should only put out 14-15v max
69Zman
05-26-2009, 01:32 PM
not running external regulator. Looking for open short or perhaps bad headlight relay etc. Thanks for the reply!
hifi875
05-26-2009, 05:55 PM
are they xs volt? if they are, there is a adjustment on the back, a small potentiometer. if not xs volt then?
recklessnova
05-29-2009, 09:32 AM
even one wire alternators have voltage regulators internaly
Bad voltage regulator or a short in the alternator could cause this easily.
Really should do a 3 wire alt
but you did what you did for a reason
Josh
