View Full Version : From Start To Finish: Chassis Build Question
Jake616
05-23-2009, 09:23 PM
In order to have a fully complete frame from start to finish, what all items need to be completed and mounted before I powdercoat my entire frame/suspension components/etc so I will not need any more grinding/adjusting/welding to it after its complete?
I want to have everything fitted including engine/transmission/hard lines for my air/fuel/ tubing ran for electrical/etc before all finish stages so that will help also.... but want to make sure I am not gonna run into any issues after?
ALL INPUT APPRECIATED! Thanks! :)
oestek
05-24-2009, 09:16 AM
I'd make sure you put everything together with the body in place... things look accessible when it's just a frame on stands, and can be in the way of something or hard to get a wrench on with the body in place. You basically have to build the car. Don't forget the e-brake lines and any exhaust hangers that attach to the frame.
Chicken Coupe
05-24-2009, 11:15 AM
Depends on how many modifications you are planning too.
If you are doing a resto, probably won't have to modify much, if anything, but if you are changing from a 6 cyl with a column mounted shifter to an LS7 and everything else from stock to aftermarket, plan on numerous "changes" that will be needed.
Might be a great "idear" to post a list of planned mods, for better guidance.
Jake616
05-24-2009, 11:46 AM
From 4 cylinder manual transmission to BBC/Manual Transmission... 6 lug to 5 lug swap/ solid axle to IRS/ through frame exhaust/ air ride/ channeled cab/ shortened bed/ disc brakes/ fuel cell/ air tanks/etc
Basically a whole new truck...
