    Results 1 to 4 of 4
      May 2006
      Wilwood brake pedal assembly and steering column clearance
      http://www.southwestspeed.com/index....g%20Mount-Long
      Has any installed this in their first gen? I need to do this because I have no way of mounting my clutch master cylinder on my firewall due to my vacuum booster on my firewall. With this pedal assembly I can mount my clutch master inside the car. Will my column be in the way of the pedals? Please help this is my last major problem I have to fix to drive my 68.
      May 2006
      Please let me know if anyone has seen an aftermarket pedal setup on a first gen. Thanks!
      May 2006
      bump
      Loganville, GA
      The only cars I have seen with the reverse mount master cylinders were in race cars. The position of the master cylinder would interfere with the dash/instrument cluster and would require a removable section in order to fill it. Plus I don't think they would work around the stock steering column. I have seen clutch master cylinders placed where the stock clutch pushrod came through. It does require a remote reservoir for it but it would probably be easier than trying to change the pedal assembly out. Here is an example:
      http://www.classicchevy5speed.com/im...ge016_0002.jpg
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
