View Full Version : Wilwood brake pedal assembly and steering column clearance
vannatta20
05-17-2009, 07:47 PM
http://www.southwestspeed.com/index.php?sec=view_menu&cat=Hubs%20And%20Brakes&sub=Pedals&ssub=Brake%20and%20Clutch%20Pedal%20Comb!os&sssub=Reverse%20Swing%20Mount-Long
Has any installed this in their first gen? I need to do this because I have no way of mounting my clutch master cylinder on my firewall due to my vacuum booster on my firewall. With this pedal assembly I can mount my clutch master inside the car. Will my column be in the way of the pedals? Please help this is my last major problem I have to fix to drive my 68.
vannatta20
05-18-2009, 03:40 PM
Please let me know if anyone has seen an aftermarket pedal setup on a first gen. Thanks!
vannatta20
05-20-2009, 12:05 PM
bump
Randy67
05-21-2009, 04:23 AM
The only cars I have seen with the reverse mount master cylinders were in race cars. The position of the master cylinder would interfere with the dash/instrument cluster and would require a removable section in order to fill it. Plus I don't think they would work around the stock steering column. I have seen clutch master cylinders placed where the stock clutch pushrod came through. It does require a remote reservoir for it but it would probably be easier than trying to change the pedal assembly out. Here is an example:
http://www.classicchevy5speed.com/images/clip_image016_0002.jpg
