Results 1 to 9 of 9
- Join Date
- Mar 2009
- Posts
- 6
Help me design an all electronic 4R70W drive train?
I’m trying to design and build a drive train that’ll shift as close to an F1 or sports racing car as I can get using reasonably priced (read cheap) parts.
I want a fully electronically shifted 4R70W. In fact I already have a junkyard one that I plan to use during the build to make sure everything will fit and possibly for a core for my final “built” transmission.
My plans are for console mounted pushbuttons (or maybe rocker switch/pushbutton combination) to control the Forward-Neutral-Reverse-Park functions. And a set of microswitches integrated into the steering wheel for up/down shifting. I have a Retrotek paddle shifter that I picked up on eBay but would prefer the steering wheel switches, I think. I may test both.
These inputs would feed the transmission controller. From my research, the Compushift seems like it may be the best choice.
It sounds like a contradiction, but right now I’m working on the build of a carburetored 351W.
This would require, at a minimum, a throttle position sensor to work with the transmission controller. I might have to wind up going EFI; if a carb/TPS setup can’t be made to work satisfactorily. But that would hit the budget pretty hard.
The actual transmission specifications are where I’m the foggiest. Except for my daily drivers, every thing I’ve had has been a manual.
I expect the engine to be in the 350 – 400 hp, 400 ft-lbs torque, range
For a road course car, I’ll need plenty of transmission cooling.
I think engine braking would also be desirable.
How would the transmission build differ from what I would expect from the typical drag oriented build? My transmission guy knows drag cars but has never done one for a track car.
I don’t have any idea what I’d need in the way of a converter, stall speed, etc.
Lots more questions than answers at this point.
Any input would be appreciated. Pretty much everything is open to review, debate, criticism and change at this point.
Thanks in advance for your help,
