View Full Version : power steering pressure ?
bret loibl
05-14-2009, 05:53 PM
What is the basic fluid pressure from a gm type II power steering pump?....Getting ready to make the lines and am not sure on the hose pressure ratings...The pump is a hi flow unit from wegners any help would be great Thanks
Rodder
05-19-2009, 08:39 PM
Max pressure is somewhere between 1000-1500 psi dpending on how the pump is set up. Use hose rated for at least 2000 psi.
CarlC
05-20-2009, 09:13 AM
Lee's set mine to 1450 psi @ 3gpm.
Hotrod406
07-26-2009, 06:10 PM
I know this is a little old but maybe someone can use this info. I am using the regular braided hose and aluminum fittings on my power steering and have been for at least 5 years now. No problems. It's not technically rated for the pressure but it works fine.
silver69camaro
07-27-2009, 08:24 AM
Are you serious?
parsonsj
07-27-2009, 09:19 AM
I hope nobody uses this "information". Most ordinary SS braided hose is rated at 300 psi, which is 5-7 times underrated for power steering. This is just a bad idea, and can potentially have serious consequences.
jp
ErikLS2
07-27-2009, 01:06 PM
I can't recall where I got it from but I made some P/S pressure hose out of a steel braided teflon hose and a hose end slightly different than your regular AN fittings. I thought I got it from Speedway Motors but can't find it now on their website. I don't know anything about this place but I found some here http://www.delikon.com/teflon.html
dhutton
07-27-2009, 01:37 PM
Russell makes teflon lines pressure rated hose and fittings that you can get from Summit.
Vegas69
07-27-2009, 01:45 PM
Don is right on the money. They aren't much fun to make, but I used them on my ride. You have a ticking time bomb there hotrod.
parsonsj
07-27-2009, 01:47 PM
I'm using the Russell teflon hose. It works fine, and is rated for power steering, but I want to swap it out for some Brown and Miller stuff:
http://www.bmrs.net/smooth_bore_2-2.htm
jp
CarlC
07-27-2009, 10:02 PM
jp,
That looks like a standard industrial Aeroquip crimp-on fitting. You should be able to have a local shop build something similar. That way if you have two 90's on a hose you can clock them before the final crimp.
Mike Holleman
07-30-2009, 03:49 AM
Change them out with Aeroquip TFE hose and fittings before they kill you.
Mike
