View Full Version : Fuel Tank Advice..Stock tank with EFI setup?
Rommel
05-09-2009, 07:56 PM
I am installing an EZ EFI setup in a couple of weeks on my 68 FB, and I purchased the master kit which comes with fuel lines/filter/external pump, etc. I don't want to purchase a new tank, especially since my pump is external (with the kit), but I'm concerned about how to do the return line back to the tank. I was thinking of just adding an AN fitting, but don't know where in the tank this should be placed, or I could purchase a new sending unit that has a return line built in (most A/C cars had this). The second concern is fuel starvation. I've never baffled a tank, but don't mind trying, just don't know if it is necessary, or how exactly to do it. Any advice. I've seen the threads about the spectra tanks, and Ricks, but can it be done right without buying new? Thanks
Turbo67camaro
05-09-2009, 08:40 PM
Hard acceleration or cornering adds more baffle / sump requirements due to fuel sloshing around. Interrupt fuel to the pump and the engine will stall. Decide what type of driving you'll do with the car and go from there.
Rommel
05-10-2009, 03:34 AM
I'll certainly be doing some hard cornering, and acceleratin.
neki67
05-10-2009, 05:59 AM
You could try one of these: http://store.summitracing.com/partdetail.asp?autofilter=1&part=CEE%2D4041&N=700+400079+115&autoview=sku
Have a look at the instructions: http://static.summitracing.com/global/images/instructions/cee-4041.pdf and you will see that it will most likely give you all you need.
rickk
05-10-2009, 07:17 AM
use your stock tank just put sump in it.
rick k
Motown 454
05-10-2009, 07:44 PM
What do you guys think of something like this Aeromotive sump?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=AEI%2D18650&N=700+115&autoview=sku
Has anyone used anything like it? Do you think it would work? I'm guessing you leave it raised above the floor of the tank to form the sump its pretty deep.
Mkelcy
05-10-2009, 08:00 PM
http://www.camaros.net/forums/showthread.php?t=116648 If you have any question, fell free to ask.
Rommel
05-12-2009, 08:18 PM
Thanks for the info, I will probably sump the tank, and see how it goes, I was looking for an easy inexpensive solution, and so far this appears to be the way to go. Is anyone using a low pressure pump to fill a small can, and then having the high pressure pump pull from the can?
Turbo67camaro
05-12-2009, 08:32 PM
I've not done that personally, but I've read others are feeding a surge tank like you describe with success.
liquidh8
05-13-2009, 03:02 AM
x2 for the surge tank, that is what I am trying next. I have 2 sumped tanks in 2 different cars, and they are no good for spirited street driving with under 6 gallons in the tank (18 gallon tank)
zboss86
05-16-2009, 03:05 PM
Has any body tried one of these tanks? It has a built in fuel pump...
https://static1.pt-content.com/images/pt/2009/05/ce29_1_sblJPG-1.jpg
http://cgi.ebay.com/ebaymotors/1967-68-CAMARO-FIREBIRD-FUEL-INJECTION-FUEL-TANK_W0QQcmdZViewItemQQ_trkparmsZQ7c301Q3a1Q7c293Q 3a1Q7c294Q3a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQ hashZitem4ce36a94afQQitemZ330232927407QQptZMotorsQ 5fCarQ5fTruckQ5fPartsQ5fAccessories
Rebob
05-16-2009, 05:14 PM
Rock Auto has those tanks for about $450.
TraviZ28
05-16-2009, 05:27 PM
just tap your return line into the top of the tank and let it free flow. putting it at the bottom of the tank can create negative pressure on the return.
zboss86
05-16-2009, 07:15 PM
Oh, ok... that's the spectra fuel tank. I didn't realize that.
zboss86
05-16-2009, 07:18 PM
I had a friend that did that... He put a fuel pump "sock" on the end of the line. I was told he can run it near empty with no problems.
Chevy Kid
05-17-2009, 08:18 AM
I respectfully disagree. Every factory in tank set up has the return buried in the bottom of the tank next to the pickup.
If this causes a negative pressure situation as you say, what happens when the tank is completely full?
I think the system will work both ways. Mine just dumps in the fuel filler. Works great, but now I'm fighting a fuel smell problem when it's parked. My Dad seems to think the pick up should be buried.
Tim
keith1365
05-26-2009, 08:47 PM
I used a stock fuel tank and added a return line into the stock fuel line and gauge insert in the tank. I just brazed a 3/8 stainless line with a 90 degree bend on the bottom of it. I am using an external fuel pump and have done some spirited driving with it. I have never been below 5 gallons in the tank and have never had a starvation problem. Fuel pressure has never dropped. Just my experience. My cornering has all been short hard corners, never any long sweepers so the fuel maybe has not had enough time to move away from the pickup.
z06fromhell
05-27-2009, 02:13 PM
if it helps anyone, i have a 67-68 tank on ebay with a competition engineering 4041 sump welded on for around 100 bucks.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sellerpreview=true&item=320374883766&sspagename=STRK%3AMESELX%3AIT
724tim
05-27-2009, 04:34 PM
I used a stock fuel tank with the competition engineering 4041 sump kit from summit racing and used my original feed line as my return no problems.
zboss86
06-07-2009, 07:31 PM
that would probably work pretty well... I can't weld to well, so I'm thinking about using Rock Valley's tank.
