View Full Version : nova dash in camaro
motion clone
05-07-2009, 04:16 PM
hi does anyone know if you can use a 69 nova covan dash in a 69 camaro i had heard you cn thanks
ProBell
05-07-2009, 04:37 PM
If you can get the 2 cars side by side just check the total width of the dashes. If that part is close you should be able to do it with some work. I put a 99 Camaro dash in my 67 Camaro and a 87 Camaro dash into a 79 ElCamino. Just takes time. Good Luck Randy
indebt69
05-07-2009, 05:01 PM
Do a search. I saw a guy that did and has some pictures. Uses the dash pad of the nova also. Hope that helps.
jfaria78
05-07-2009, 06:01 PM
yes you can, but you have to use a nova dash pad.
ebncrdr
05-07-2009, 06:33 PM
exactly
DRJDVM's '69
05-07-2009, 11:09 PM
Yes....I did it. Alittle trimming here and there....alittle moving of the screw mounts...nothing major. But yes you need to use a Nova dash pad. That also takes some trimming etc. I bought a used one on ebay, trimmed it to fit and then had it recovered in the same vinyl as my door panels etc
motion clone
05-08-2009, 05:09 AM
thank you for the helpfull info
