View Full Version : stock ecu controlling ac
B Schein
04-12-2009, 09:24 AM
I have been working on my 00 camaro harness for my conversion I have it pretty much done but I want to run the ac through the pcm so the fans work right and the idle kicks up. Their are two ac wires that I havent removed ac request and ac clutch relay control. I beilve I should hook up the request to my Vintage air control. What is the clutch relay control hook up to. I reaserch on ls1 tech couldnt realy find an answer. I did find some info on people using the stock presure switch do you need this for the computer to turn on the compresior?
rockytopper
04-13-2009, 09:50 AM
Here is one link I found with a quick search hope it helps. Good luck with your build
http://www.ls1tech.com/forums/conversions-hybrids/1094106-hot-rod-air-controlled-computer.html
