View Full Version : Question about deep scratches.
muthstryker
04-11-2009, 08:38 PM
Hey guys, After painting the tempest today there are alot of deep scratches on the trunk lid, What would be the best way to go about "getting rid" of them. I have some evercoat glazing putty that ive never used. Should I use that? Or should I just use my filler?
CANADABOY1989
04-11-2009, 09:26 PM
Did you put a clearcoat over it already or did you use single stage
muthstryker
04-11-2009, 09:31 PM
good ol rattle can paint nothing special but the scratches bug me.
CANADABOY1989
04-11-2009, 09:33 PM
what did you sand the primer with before you painted it?
muthstryker
04-11-2009, 09:38 PM
used 120 grit but these things are deep. didnt notice them at all. Looks like a razor blade was dug into it
CANADABOY1989
04-11-2009, 09:44 PM
ya 120 scratches are too big for paint to fill in on primer, sand it down with a block with 180 grit dry then go back over it all with 400 wet and if you can see them still then use 600 wet. this will knock the primer down to a near flat surface. that should get rid of your scratches, what colour did you paint it?
muthstryker
04-11-2009, 09:45 PM
its black.
CANADABOY1989
04-11-2009, 09:47 PM
if you take a rattle can of white paint and put a quick mist coat on it as you sand it the white paint will stay in the scratches and disappear as you sand the scratches out
muthstryker
04-11-2009, 09:49 PM
I will give that a try
CANADABOY1989
04-11-2009, 10:05 PM
k let me know and that is going to be a sick gto when ur done, keep adding pix of it
