View Full Version : My old sub-frame connectors....
trapin
04-07-2009, 08:20 AM
I got a set of sub-frame connectors that I bought way back in the Upper-Paleozoic Era. I think they are from Competition Engineering.
They look like this...
https://static1.pt-content.com/images/pt/2009/04/cee3112-1.jpg
I'm wondering if I can get away with using these for now until I can get something fancier down the road. Will they hang down too low for a car like mine and give me fits going over curbs? Or can I get away with it?
Thanks.
rlovell383
04-07-2009, 08:28 AM
I've had those exact ones in my car for years, and I like them. They noticeably stiffen the car, and I've never had any clearance issues. They arent as fancy as some other brands, but I like em. They dont hang down all that bad. Pics of my car in this thread.
https://www.pro-touring.com/forum/showthread.php?t=54435
Randy
Damn True
04-07-2009, 09:03 AM
Bolt em in for now and run it. If they work fine and don't drag you'll be solid and won't have to spend any more $$. If they give you fits you can get some weld in dealies and install them over next winter.
trapin
04-07-2009, 10:28 AM
OK, thanks. I just wanted to see if anyone else was running them and if they had problems with them. I will have to see how the budget goes, if I can afford some nicer ones this Summer I'll go for it. If not I'll just bolt these puppies in.
6'9"Witha69
04-07-2009, 10:43 AM
Those can be welded too. I had a set welded in once. My current ones are only bolted in, until the GW ones in my rafters get installed. Make sure to replace the j nuts even if the old ones look usable. It is cheap insurance now.
04-07-2009, 09:09 PM
I've actually cut a set of those up and re-welded them into the car to sit higher. Came out pretty good.
vince
